Hello, back once more with a Geoprocessing object error ... I am trying to perform a Getis-Ord analysis for one of my applications (written in C#), and I'm getting an error that I cannot add a field created from the analysis into the new feature class. My code is the following: gp.AddToolbox(@C:\Program Files (x86)\ArcGIS\Desktop10.0\ArcToolbox\Toolboxes\Spatial Statistics Tools.tbx); IVariantArray parameters = new ESRI.ArcGIS.esriSystem.VarArrayClass(); parameters.Add(DatabaseUtils.ScratchDBPath + "\\" + inFeature); parameters.Add(field); parameters.Add(DatabaseUtils.FGDBPath + "\\" + outFeature); parameters.Add("INVERSE_DISTANCE"); parameters.Add("EUCLIDEAN_DISTANCE"); parameters.Add("NONE"); parameters.Add(200); try { IGeoProcessorResult res = (IGeoProcessorResult)gp.Execute("HotSpots", parameters, null); } catch (System.AccessViolationException avEx) { avEx.emailError(gp); } catch (System.IO.FileLoadException flEx) { flEx.emailError(gp); } catch (Exception ex) { ex.emailError(gp); } finally { gp = null; }This is also in the error:A column was specified that does not exist.
A locator with this name does not exist.
Failed to execute (HotSpots).One thing to note is that I am deleting an existing feature class in an SDE database (programmatically), and creating a new one with the same name using the analysis ... I don't think this has anything to do with this, considering the feature class looks to be created, but the fields are not added.
