hello, I can't dissolve for multipatches, I want to merge geometries like merge in edit, but I can't do that in python. is there a way
Greetings,You can check if features are inside the multipatch using Inside 3D. Use the create Complex Output Table (optional) parameter to identify the relationship between the features and multipatches through the creation of a Contain_ID field, which could later be used to do a standard table join.Another workflow would be to run the MultiPatch Footprint tool to get 2d representations of the multipatches and use those polygons to do the spatial join. Then table join it back to the multipatch feature class.Regards,Eric
