Lefteris, Do you have the ability to change code in the Viewer?
private function initBasemapButtonBar():void { basemapList = new ArrayList(); var labels:Array = []; for each (var basemap:Object in configData.basemaps.reverse()) { var label:String = basemap.label; if (labels.indexOf(label) == -1) // avoid duplicates using the labels { labels.push(label); basemapList.addItem(basemap); } } if (basemapList.length <= 1) { this.currentState = "noBasemaps"; } else { setBasemapButtonBarIndexToTopmostVisibleBasemap(); } }
Lefteris, Than the cahnge is a simple as this, In the MapSwitcherWidget.mxml change this function as indicated below: private function initBasemapButtonBar():void { basemapList = new ArrayList(); var labels:Array = []; for each (var basemap:Object in configData.basemaps.reverse()) { var label:String = basemap.label; if (labels.indexOf(label) == -1) // avoid duplicates using the labels { labels.push(label); basemapList.addItem(basemap); } } if (basemapList.length <= 1) { this.currentState = "noBasemaps"; } else { setBasemapButtonBarIndexToTopmostVisibleBasemap(); } }Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
Lefteris, So do you see anything displayed in your problems window in Flash Builder? I tested this on my end and it works fine...
