Private Sub RequestData(attributes As IDictionary(Of String, Object)) If attributes IsNot Nothing AndAlso Not String.IsNullOrEmpty(ObjectIDField) AndAlso attributes.ContainsKey(ObjectIDField) AndAlso TypeOf attributes(ObjectIDField) Is Integer Then Dim objectId As Integer = CInt(attributes(ObjectIDField)) If objectId = _currentId OrElse _cachedItems.Contains(objectId) Then 'Item has already been requested Return End If Dim qt As New QueryTask() With {.Url = QueryUrl} Dim q As New Query() q.ReturnGeometry = True If QueryOutFields IsNot Nothing Then For Each outfield As String In QueryOutFields If Not attributes.ContainsKey(outfield) Then q.OutFields.Add(outfield) End If Next Else q.OutFields.Add("*") End If If q.OutFields.Count > 0 Then _cachedItems.Add(objectId) q.Where = String.Format("{0}={1}", ObjectIDField, objectId) AddHandler qt.ExecuteCompleted, AddressOf qt_ExecuteCompleted AddHandler qt.Failed, AddressOf qt_Failed qt.ExecuteAsync(q, New Object() {attributes, objectId}) _currentId = objectId _dataRequestInProcess = True ChangeVisualState(True) End If End If End Sub Private Sub qt_ExecuteCompleted(sender As Object, e As QueryEventArgs) Dim state() As Object = CType(e.UserState, Object()) Dim attr As IDictionary(Of String, Object) = TryCast(state(0), IDictionary(Of String, Object)) Dim oid As Integer = CInt(state(1)) If e.FeatureSet.Features.Count > 0 Then 'Copy the attributes over to the attribute collection for the feature we requested for For Each item As KeyValuePair(Of String, Object) In e.FeatureSet.Features(0).Attributes attr(item.Key) = item.Value Next attr.Add(New KeyValuePair(Of String, Object)("_geometry", e.FeatureSet.Features(0).Geometry)) If _currentId = oid Then 'False if a new element got opened before request returned _dataRequestInProcess = False ChangeVisualState(True) End If End If End Sub
