Thanks jeff.pace for the referral, I will look closely into this.
You want feature Layers. You would set up the entire dataset on the server, and then the HTML/javascript can dynamically apply filters or queries.
Hi Scott,I don't quite follow what you want to do... Are you looking to create an app that will allow the user to download their gps and display the data right then? There are a few samples out there that allow the user to download to a .csv file or .gpx file (or other formats), upload them to a server, and then display the results on a map. There are also some samples that allow the user to drag and drop files onto the map and display the results (with newer browsers). Another option might be to look into the Garmin Communicator API (if the data is coming from a Garmin gps unit). You could set up an application that allows the user to download data into json format, and use that right in your mapping application. Can you provide a few more details on your project?Ken
Hello all,I have a client who is in need of mimicking their ArcGIS desktop version via a webapp. Currently we have a database consisting of various entries dealing with GPS point placement, layering, etc and would like to somehow bring this functionality to the web, even minimally. Essentially, if I select parameters the run against the database such as temperature, location, time intervals, etc. - the webapp app queries the database, pulling GPS data, and then displaying points and so forth on the map on the page after the user hits the "Update Map" button.I have yet to find any good examples of something similar of this being done - i.e. HTML querying and map updating in real time instead of just pulling/pre-loading from some KML/CSV on a distant server.Thank you so much for your time. Any help will be sincerely appreciated!-Scott
