...some commands cannot be used on specific operating systems. These are as follows: Linux 64-bit: cov2sde and sde2cov HP Itanium: cov2sde, sde2cov, sde2shp, shp2sde, sde2tbl, tbl2sde, and shpinfo
You are correct, Alex. The operating system/command line utility combinations you have listed are the only ones that are not supported for 10.1.-Kim
If it's a geodatabase, then you really ought to be using ArcGIS tools (Desktop / Catalog / arcPy)to load shapfiles. The command-line 'shp2sde' is still supported for simple feature class creationon the most common platforms at 10.1 (HP/UX Itanium is the only platform not supported).- V
@echo off REM shp2sde.bat set SDEHOME=D:\Esri\arc100ora11g32-sp5\ArcSDE\ora11gexe set PATH=%SDEHOME%\bin;%PATH% %SDEHOME%/bin/shp2sde %*
