Greetings,Would this bug (NIM059884) be the cause of why my AutoCAD drawings drawn 1:1 scale are showing up 12x when imported into ArcGIS? Or should I look elsewhere?Thank you
Probably not. The work around we have found is to have the CAD drawing originator make a copy of the file and adjust the projection from "Surface to Grid." I'm not sure what would cause a CAD drawing to show up multiple times in the same ArcMap MXD. Perhaps you are seeing "scratch" areas that the Engineer/CAD Tech used to place shapes they copied alot?
Has anyone found a solution to the tranformation problem or heard if ESRI is coming up with a fix soon. Thanks.
Has the transformation problem been fixed?
