EXPORT LOG / CityEngine 2011.1.10211215---------------------------------------------------export started at: Mon Oct 22 16:12:00 2012export completed at: Mon Oct 22 16:12:00 2012export duration: 0.1 secondsEXPORT SETTINGS format: Autodesk® FBX® 2012 location: C:\Users\ifloussov\CityEngine\EdmontonOSMImport\models base name: map export content: 0 (0 = models only, 1 = fallback to shape, 2 = shapes only) file granularity: 0 (0 = single file (or split by file budget), 1 = file per initial shape) file size budget: 524288000 mesh granularity: 1 (0 = as generated, 1 = mesh per material, 2 = use instances of inserted assets) vertex precision: 0.00100 normal precision: 0.00100 texcoord precision: 0.00010 merge vertices: 1 merge normals: 1 merge texcoords: 1 triangulate: 0 reproject texcoords: 0 vertex indexing: 0 (0 = allow shared vertices, 1 = force separate vertices) normals type: 0 (0 = use vertex normals, 1 = use face normals (flat)) normals indexing: 1 (0 = allow shared normals, 1 = force separate normals) write texcoords: 1 (0 = no texcoords, 1 = first layer, 2 = all layers) write materials: 1 collect textures: 1 file type: 1 (0 = ascii, 1 = binary) embed textures: 1 write master file: 0 master group name: CityEngineSceneRoot write cam data: 1 batch behavior: 0 (0 = normal, 1 = skip existing files, 2 = dry run)INPUT STATS number of initial shapes = 2915 number of generated shapes = 0 number of generated meshes = 0 number of generated materials = 0OUTPUT STATS written files: 0 written materials: 0 written meshes (total polygons): 0 (0) mesh names (polygons):INPUT REPORT collected/generated initial shapes: 0: ERROR : shape OID: 24afa5c0-8367-11b5-a58a-0004a6b9019c:0 1: ERROR : shape_1 OID: 24afa5c0-8367-11b5-a58a-0004a6b9019c:1 2: ERROR : shape_2 OID: 24afa5c0-8367-11b5-a58a-0004a6b9019c:2 3: ERROR : shape_3 OID: 24afa5c0-8367-11b5-a58a-0004a6b9019c:3 4: ERROR : shape_4 OID: 24afa5c0-8367-11b5-a58a-0004a6b9019c:4 5: ERROR : shape_5 OID: 24afe1e0-8367-11b5-a58a-0004a6b9019c:0 6: ERROR : shape_6 OID: 24afe1e0-8367-11b5-a58a-0004a6b9019c:1 7: ERROR : shape_7 OID: 24afe1e0-8367-11b5-a58a-0004a6b9019c:2 8: ERROR : shape_8 OID: 24afe1e0-8367-11b5-a58a-0004a6b9019c:3 9: ERROR : shape_9 OID: 24afe1e0-8367-11b5-a58a-0004a6b9019c:4 10: ERROR : shape_10 OID: 24b2f44f-8367-11b5-a58a-0004a6b9019c:0 11: ERROR : shape_11 OID: 24b2f44f-8367-11b5-a58a-0004a6b9019c:1...
