//Q: http://forums.arcgis.com/threads/33463-Modify-(add)-to-MAIN-Toolbar-with-Addinx-files public class TestAddToMainMenu : ESRI.ArcGIS.Desktop.AddIns.Extension { public TestAddToMainMenu() { } protected override void OnStartup() { WireEvents(); } protected override void OnShutdown() { } private void WireEvents() { ArcMap.Events.OpenDocument += new ESRI.ArcGIS.ArcMapUI.IDocumentEvents_OpenDocumentEventHandler(Events_OpenDocument); ArcMap.Events.NewDocument += new ESRI.ArcGIS.ArcMapUI.IDocumentEvents_NewDocumentEventHandler(Events_NewDocument); IApplicationStatusEvents_Event appStatusEvents = ArcMap.Application.Document.Parent as IApplicationStatusEvents_Event; appStatusEvents.Initialized += new IApplicationStatusEvents_InitializedEventHandler(Events_Initialized); } void Events_Initialized() { // Need this to load menu when no document loaded at startup LoadCustomMainMenu(); } void Events_OpenDocument() { LoadCustomMainMenu(); } void Events_NewDocument() { LoadCustomMainMenu(); } private void LoadCustomMainMenu() { ICommandBar mainMenuBar = GetMainMenuBar(); UID uid = new UIDClass(); // make sure we got the main menu bar if (mainMenuBar == null) return; // check if our custom menu is already there string menuID = "REPLACE WITH MENU ADDIN ID"; // ID of Add-In Root Menu ICommandBar myMenu = mainMenuBar.Find(menuID, false) as ICommandBar; if (myMenu == null) { // Add Menu, if needed uid.Value = menuID; Object indexObj = Type.Missing; // adds menu at far right myMenu = mainMenuBar.Add(uid, ref indexObj) as ICommandBar; } // add further items (this can be buttons AND tools *evil grin*) uid.Value = "REPLACE WITH BUTTON ADDIN ID"; myMenu.Add(uid); uid.Value = "REPLACE WITH TOOL ADDIN ID"; myMenu.Add(uid); //[...] just add any further item, you need ((ICommandItem)mainMenuBar).Refresh(); } private ICommandBar GetMainMenuBar() { try { //Grab the root menu bar UID uid = new UIDClass(); uid.Value = "{1E739F59-E45F-11D1-9496-080009EEBECB}"; // Main menubar ICommandBars cmdBars = ArcMap.Application.Document.CommandBars; //ICommandItem commandItem = cmdBars.Find(uid, false, false); //???? return cmdBars.Find(uid, false, false) as ICommandBar; } catch { return null; } }
