dojo.connect(myLayer, "onBeforeApplyEdits", saveValues); function saveValues(adds,updates,deletes) { /** Treatements **/ }
API JS 3.0ArcGIS 10.1Oracle 11gI have a similar issue and maybe my question will answers yours. I have to intercept objects to add, update or delete before they are sent to server. Because I have to authorize each edit and complete the attributes before they are applied to database.The featureLayer get an event called onBeforeApplyEdits fired just before the applyEdits function.This event gives 3 arrays of Graphic : adds, updates and deletes. I can modify or reset adds and updates but there is no way to reset the deletes.I tried, without success: delete deletes; deletes = undefined; deletes = new Array(); It seems impossible to cancel the call to applyEdit (it's a REST request send to the server).A solution exists : to put a personal event on the delete button instead of the default one. This event would call a function wich would call applyEdits or not. But, this is not a solution if use the cut tool (my case) because updates and deletes are used and you not press a button but draw in the map.I cannot believe there is no way to cancel a delete before it is sent to the server.Maybe it will help to solve your problem but I think my situation is close so if someone have an idea.
I'm not even sure what events the editor emits, if any, but the FeatureLayer has an "onEditsComplete" that will let you know what was deleted.http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jsapi/featurelayer.htm#onEditsComplete
