Thanks for the tip, I have had a similar problem earlier but it was always solved by registering the source. Will ask our administrator to change that setting.By reading the documentation I found that Sql Azure apparently cannot be used as a geodatabase: ArcGIS geodatabases are not supported with Windows Azure SQL Database. (http://resources.arcgis.com/en/help/system-requirements/10.1/index.html#//01510000008m000000). This is a strange to me since I can create feature classes and populate it with spatial data and visualize it in ArcMap.
I was hoping that I would be able to prepare a mxd document in ArcMap and publish that as a ArcGIS mapservice. Using the ArcGIS Spatial Data Server will not allow that as it streams the data to the client which is then responsible for the drawing.
