When you make a query request to the server, you have to wait for the results to come(unless you are binding the executelastresult to a component). This can be achieved by either:1.Using Responder sample for using the same is at: http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=QueryResultsWithChart2. Adding executeComplete event listener to querytask and in event handler perform rest of your steps: i.e.var num:int = queryTask.executeLastResult.features.length; Alert.show(num.toString()); if ( num != 1){ Alert.show("All stops must be located inside Philadelphia County"); return; } var point:MapPoint = event.mapPoint; var myGraphicMarker:Graphic = new Graphic(point,userMarks); myGraphicMarker.toolTip = "Added stop"; userClicks.add(myGraphicMarker); stops.push(myGraphicMarker); messages.text = stops.length.toString() + " total stops"
