Drone2Map will not install. It keeps asking for the C++ runtime 2008 Redistributable even though i have already installed it.
Jon,
You need a specific version of the Microsoft Visual C++ 2008 Redistributable: Version 9.0.30729.6161
Download Microsoft Visual C++ 2008 Service Pack 1 Redistributable Package MFC Security Update from Official Microsoft Do…
Not sure if this is the problem but it may worth looking into.
jt
Yes. That did the trick. Thanks
Jon... It might be a wider issue with your system. Since you didn't find any links with that error and a drone2map install, it might not exist with others but only on yours. I would contact tech support with your details.
I looked at most of those and non refer to issues installing Drone2Map. I have uninstalled and reinstalled the C++ package and it still will not install.
There are a number of threads using .... drone2map 2008 ... yields numerous hits of various bits of info... you might want to have a read .... https://community.esri.com/message/633164-re-drone2map-samples-not-processing-not-yet-answered?commentID=633164#comment-633…
