As far as I can see there is no direct support for SQLLite in Pro. Is that a planned feature ? Can I access SQLite through phyton and import data as layers that way?
It is true that sqlite is still not supported for interactive editing as at Pro 2.3 and it is also not supported for editing in ArcMap.
But don't let that put you off using sqlite and the spatial extensions combined with Esri tools. It is still very useful for lots of purposes. It can fill in holes in ArcTools and for some operations it is 100 times faster.
The way I use it is to keep the spatial tables (ie featureclasses) and aspatial tables (ie tables) in sqlite (with the spatial extension DLL built into Arc*) and run python scripts with SQL commands. You can do any (non interactive) editing with that method!
After a few seconds of processing I then copy the spatial tables back into a filegeodatabase if I need to use other tools that do not support sqlite. I can see the featureclasses and tables in ArcCatalog and they can usually be a read-only source of data.
The great benefit to exporting data as a sqlite database is that I can send it to a user without a GIS installation and they can easily read it with an ODBC driver.It is a single file database excellent for exchange. There are no size limits. Some of my databases are 6GB. Because they have good indexing they are way faster than Access ever was. Instead of an awful CSV file you get a proper database table with a full schema, metadata, and the flexibility of a relational database.
Need the equivalent of Access?There are several open source equivalents available
I purchased sqlitepro http://www.sqliteexpert.com
to test out my sql expressions.
What sort of tools? Consider if you have a many to one relate between owners and parcels. You would like a point layer of owners 'geocoded' by using the parcel centroid. The obvious solution is to add a spatial column to Owners and populate it with parcel centroids from a relate to the parcels. This typically takes 2 minutes for 5 million records. This is not easy with ArcTools. MakeQueryLayer is not available for filegeodatabases, MakeQueryTable is slow, does not scale well enough to complete. The only workaround I have found is to create a new empty Owner featureclass, copy all the data across with a cursor, then create a dictionary of geometry objects from the parcels and update the Owner featureclass. This takes some advanced python skills so I may as well write a SQL expression in spatialite (sqlite + mod spatialite)
sql <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="string token">"UPDATE {0} SET shape = (SELECT shape FROM parcel.Parcel_Label B WHERE B.par_id = {0}.first_par_id) "</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">format</SPAN><SPAN class="punctuation token">(</SPAN>new_title<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
time 0:00:17.682000count 2149376
This was as expected because it was a port from ARC/INFO and AML which took a similar time.
Confirmed. I have successfully created both a Spatialite and GeoPackage database. However, I cannot edit the data...getting a 'not registered in the Database' error. I try to register the data and that also errors out. Is it possible to edit SQLite databases in Pro, and if so how does one do this?
I think mobile geodatabases (.geodatabase) are great, SQLite meets geodatabase. Does Esri have plans to support native access within the desktop clients instead of having to convert back and forth between file geodatabases?
Sqlite, SpatiaLite and GeoPackages are supported in Pro. Mobile Geodatabases (.geodatabase) support is being considered for a later release, but not in the Pro 2.1 currently under development.
Lance
Is there any update on this? I would like to open a sqlite geodatabase (a ".geodatabase" file) in ArcMap or ArcGIS Pro. Is this possible?
Brad
As far as I know, the below workspaces are not yet supported with ArcGIS Pro:
Presently supported Workspaces should be --
Thanks Josh, I am trying both simple table and spatial data. Also tried to start of with a SQLite created by ArcGIS. It doesn't make any difference. In the GUI neither the extension .sqlite or .gpkg is recognized in pro, but works fine in ArcMAp 10.3 with the same tools.
Are you trying to load spatial data or just a table? Was the SQLite database created by ArcGIS Desktop or some other application? If the latter, try making a SQLite database from ArcGIS Desktop and putting some data in it, and then see if ArcGIS Pro sees that database, especially if working with spatial data.
Just tested the Make Feature Layer Tool on version 1.0 and it does not see sqlite as a valid data source in the GUI. I could also not make it work using scripting directly, but that could be for other reasons as the error message is quite generic.
Strange though, because looking in the Pro folder structure both sqlite3 and ST_Geometry dlls are distributed with Pro.
I think Esri would agree, i.e., SQLite isn't currently fully supported in ArcGIS Pro.
Although "seeing" SQLite databases isn't possible through the Project pane/window, you can load SQLite databases using the Make Feature Layer tool either through the GUI or ArcPy. At least during beta testing, Spatialite-based spatial data wouldn't load because the correct DLLs weren't packaged with the installer, not sure if that changed. I have successfully loading ST_Geometry and GeoPackage spatial data into ArcGIS Pro.
