I'm having difficulty with this.I've followed the installation instructions, but when attempting to start SDE I get an error:"Operation Failed, Unable to start iomgr."ArcSDE is installed on a RHEL 6.4 machine, which uses xinetd rather than inetd as it's service daemon. Adding the service requires slightly different steps as compared to with inetd. in /etc/xinetd.d/ I created esri_sde which containsservice esri_sde
disable = no
socket_type = dgram
wait = yes
server = /opt/test/sde/sdeexe102/bin/sderemote
server_args = iomgr_inetd
user = sde
protocol = udp
type = INTERNAL
id = time-dgram
}/etc/xinetd.d itself was edited to contain"esri_sde"/etc/services was edited to contain esri_sde and port number.I am not clear on the contents of the dbinit.sde fileThe following is example information copied from http://help.arcgis.com/en/geodatabase/10.0/admin_cmds/support_files/serveradmin/sdemon.htmset ORACLE_HOME=/bluebeard/oracle
set ORACLE_SID=ora
set LD_LIBRARY_PATH=/usr/lib:/bluebeard/oracle/lib:/bluebeard/oraexe/sdeexe91/lib
What is the value of ORACLE_HOME?Oracle is not installed on the same machine as SDE. There is no ORACLE_HOME for this machine.Any suggestions?
