Identify from ButtonI was on here working out a solution to fire some code that did a buffer and selection of features within and return to a grid. That works, but I now have a button that I want to run an identify and send results to a side bar. I believe the code is in place to pause the buffer code when switching between buttons. But the way I have it set up below its requiring a click event on the map to start running the Identify code...if I click a feature in the map it does not run the code. So I am confused on how to start the Identify Trying to call the identify sidebar code in redthe blue is where I am seeing a required map click to run the code...but it does not fire when I click a feature I want to identify on.When I click the map I am not even getting to the Function and the alert.... alert("In SidebarApp");Thoughts?Thanks
on(dojo.byId('Identify'), "click", function () {
if (Buffer != undefined) {
Buffer.pause();
if (Identify == undefined) {
Identify = on.pausable(app.map, "click", function (evt) {
initializeSidebar(map);
else {
Identify.resume();
});// SIDEBAR IDENTIFY START
function initializeSidebar(map){
var popup = map.infoWindow;
//when the selection changes update the side panel to display the popup info for the
//currently selected feature.
connect.connect(popup, "onSelectionChange", function(){
displayPopupContent(popup.getSelectedFeature());
//when the selection is cleared remove the popup content from the side panel.
connect.connect(popup, "onClearFeatures", function(){
//dom.byId replaces dojo.byId
dom.byId("featureCount").innerHTML = "Click to select feature(s)";
//registry.byId replaces dijit.byId
registry.byId("leftPane").set("content", "");
domUtils.hide(dom.byId("pager"));
//When features are associated with the map's info window update the sidebar with the new content.
connect.connect(popup, "onSetFeatures", function(){
dom.byId("featureCount").innerHTML = popup.features.length + " feature(s) selected";
//enable navigation if more than one feature is selected
popup.features.length > 1 ? domUtils.show(dom.byId("pager")) : domUtils.hide(dom.byId("pager"));
function displayPopupContent(feature){
if(feature){
var content = feature.getContent();
registry.byId("leftPane").set("content", content);
function selectPrevious(){
map.infoWindow.selectPrevious();
function selectNext(){
map.infoWindow.selectNext();
function clearContent() {
