var cred = "esri_jsapi_id_manager_data"; function init() { loadCredentials(); //see if cred. already exists for this session esri.config.defaults.io.proxyUrl = "proxy.php"; esri.config.defaults.io.alwaysUseProxy = false; var process = function(ref) { var def = new dojo.Deferred(); if (ref != "" && esri.id.credentials.length == 0) { var refToken = esri.request({ url : "https://gis.ourdomain/arcgis/", //any url that's proxied in proxy content : { ref : ref }, handleAs : "json" }); function success(res) { var idObject, idJson; if (res.token != 'noToken') { var serverInfo = { "server" : "https://gis.ourdomain.com", "tokenServiceUrl" : "https://gis.ourdomain.com/arcgis/tokens/", "currentVersion" : 10.11 }; var securedServices = []; //i guess this doesn't have to be a complete list securedServices.push("https://gis.ourdomain.com/arcgis/folder/MapServer/0"); var creationTime = (new Date).getTime(); var idString = dojo.toJson({ "serverInfos" : [serverInfo], "credentials" : [{ "userId" : 'auser', //user that was hard coded "server" : serverInfo.server, "token" : res.token, "expires" : res.expires, "ssl" : false, "creationTime" : creationTime, "resources" : securedServices }] }); if (supports_local_storage()) { // use local storage window.localStorage.setItem(cred, idString); idJson = window.localStorage.getItem(cred); } else { // use a cookie dojo.cookie(cred, idString, { expires : 1 }); idJson = dojo.cookie(cred); } if (idJson && idJson != "null" && idJson.length > 4) { //load the credential idObject = dojo.fromJson(idJson); esri.id.initialize(idObject); } def.callback("loaded"); } else { def.callback("not loaded"); //proxy didn't return token for 1 reason or other } } refToken.then(success); } else { def.callback("not loaded"); //no referrer or already logged in } return def; } var ref = document.referrer; process(ref).then(function(response) { //continue adding layers, ect... }) }
$targetUrl = $_SERVER['QUERY_STRING']; $parts = preg_split("/\?/", $targetUrl); $targetPath = $parts[0]; $qStringArr = array(); parse_str($parts[1],$qStringArr); // open the curl session $session = curl_init(); if(array_key_exists('ref', $qStringArr) && $qStringArr['ref'] != ''){ //esri.request call with referrer if($qStringArr['ref'] == 'https://theReferrer.com/imLookingFor.html'){ $data = array( 'username' => 'auser', 'password' => 'auserpassword', 'client' => 'ip', //for dev only, switch to http referr on production 'ip' => '123.123.22.41', 'expiration' => '60', 'f' => 'json' ); $postData = http_build_query($data); $targetUrl = "https://gis.ourdomain/arcgis/tokens/generateToken"; } else{//referrer didnt match, return junk response echo json_encode(array('token'=>'noToken')); exit; } } else{ //continue w/ normal proxy call $postData = file_get_contents("php://input"); } //omitted cURL options array $response = curl_exec($session); echo $response;
function init(){ esri.config.defaults.io.proxyUrl = "proxy.php"; var ref = document.referer; var request = esri.request({ url:window.location.href, content:{ ref:ref }, handleAs:"json" },{useProxy:true}); function suc(response){ var idString = dojo.toJson({ "serverInfos": [serverInfo], "credentials": [{ "userId": rahul, "server": "http://myserver:8399", "token": this.token, "expires": this.expires, "ssl": false, "creationTime": creationTime, "resources": securedServices }] }); // store it client side if (_supports_local_storage()) { window.localStorage.setItem(this.token._jsAPIIDManagerData, idString); } else { dojo.cookie(this.token._jsAPIIDManagerData, idString, { expires: 1 }); } loadcredentials(); } function err(response){ console.log('response'); } request.then(suc,err); }
