I have a number of featureclasses using the projected coordinate system
NAD_1983_HARN_StatePlane_Oregon_North_FIPS_3601_Feet_Intl
which uses as a geographic coordinate system (GCS)
NAD_1983_HARN
I am trying to convert these using the Project tool in the ArcMap toolbox
to
WGS_1984_Web_Mercator_Auxiliary_Sphere based on GCS_WGS_1984
When I use the tool it suggests using the transformation named
NAD_1983_HARN_To_WGS_1984_2
In ESRI's documentation (https://support.esri.com/en/Technical-Article/000005929)
it says never to use the transformation
NAD_1983_To_WGS_1984_2
It is a bit confusing. These two transformations, one from 1983_HARN, the other without the _HARN in the name,
are they completely different transforms? Is that the best transformation to use in Oregon, North?
