<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx"> <fx:Script> <![CDATA[ import com.esri.ags.FeatureSet; import com.esri.ags.Graphic; import com.esri.ags.events.LayerEvent; import com.esri.ags.layers.FeatureLayer; import com.esri.ags.layers.supportClasses.Field; import com.esri.ags.tasks.supportClasses.Query; import mx.collections.ArrayCollection; import mx.controls.Alert; import mx.rpc.AsyncResponder; import mx.rpc.Fault; import mx.utils.StringUtil; import spark.components.gridClasses.GridColumn; [Bindable] private var gridSource:ArrayCollection = new ArrayCollection(); [Bindable] private var gridColumns:ArrayCollection = new ArrayCollection(); private var queryLayer:FeatureLayer = null; private function initializeLayer():void { queryLayer = new FeatureLayer(txtServiceUrl.text); queryLayer.mode = FeatureLayer.MODE_ON_DEMAND; queryLayer.outFields = new Array("*"); queryLayer.addEventListener(LayerEvent.LOAD, onLayerLoaded, false, 0, true); dispatchEvent(new LayerEvent(LayerEvent.LOAD, queryLayer)); } protected function onLayerLoaded(event:LayerEvent):void { queryLayer.removeEventListener(LayerEvent.LOAD, onLayerLoaded); txtServiceUrl.editable = false; executeQuery(); } protected function onExecuteButtonClick(event:MouseEvent):void { if (queryLayer != null && queryLayer.loaded) { executeQuery(); } else { initializeLayer(); } } private function executeQuery():void { var query:Query = new Query(); query.where = txtWhere.text; var outs:Array = StringUtil.trim(txtOuts.text).split(","); query.outFields = queryLayer.outFields = outs; queryLayer.queryFeatures(query, new AsyncResponder(onQueryResult, onQueryFault)); } protected function onQueryResult(featureSet:FeatureSet, token:Object = null):void { gridSource = new ArrayCollection(); lblResultsCount.text = StringUtil.substitute("Found: {0} features.", featureSet.features.length); for each(var gr:Graphic in featureSet.features) { gridSource.addItem(gr.attributes); } gridSource.refresh(); gridColumns = new ArrayCollection(); for each (var field:Field in featureSet.fields) { var gridColumn:GridColumn = new GridColumn(field.alias); gridColumns.addItem(gridColumn); } gridColumns.refresh(); } protected function onQueryFault(fault:Fault, token:Object = null):void { trace(fault.getStackTrace()); Alert.show("Query faults.", "Error"); } protected function onGetLastResults(event:MouseEvent):void { if (gridSource) // != null { var messgae:String = StringUtil.substitute("Last results length is {0}", gridSource.length); Alert.show(messgae, "Message"); } else { Alert.show("No last results found!", "Warning"); } } ]]> </fx:Script> <s:Panel width="100%" title="Query parameters"> <s:VGroup gap="5" paddingLeft="5" paddingTop="5" paddingRight="5" paddingBottom="5" width="100%"> <s:HGroup width="100%"> <s:Label text="Url:" width="150" /> <s:TextInput id="txtServiceUrl" width="100%" text="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5" /> </s:HGroup> <s:HGroup width="100%"> <s:Label text="Where clause:" width="150" /> <s:TextInput id="txtWhere" width="100%" text="1=1" /> </s:HGroup> <s:HGroup width="100%"> <s:Label text="Out fields (CSV):" width="150" /> <s:TextInput id="txtOuts" width="100%" text="STATE_NAME,STATE_FIPS,SUB_REGION,STATE_ABBR,POP2000,POP2007" /> </s:HGroup> <s:HGroup width="100%"> <s:Button label="Execute" click="onExecuteButtonClick(event)" /> <s:Button label="Last result length" click="onGetLastResults(event)" /> </s:HGroup> </s:VGroup> </s:Panel> <s:Panel title="Results" width="100%" height="100%"> <s:VGroup gap="5" paddingLeft="5" paddingTop="5" paddingRight="5" paddingBottom="5" width="100%" height="100%"> <s:Label id="lblResultsCount" /> <s:DataGrid width="100%" height="100%" dataProvider="{gridSource}" columns="{gridColumns}"/> </s:VGroup> </s:Panel> </s:Application>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx"> <fx:Script> <![CDATA[ import com.esri.ags.FeatureSet; import com.esri.ags.Graphic; import com.esri.ags.layers.supportClasses.Field; import com.esri.ags.tasks.QueryTask; import com.esri.ags.tasks.supportClasses.Query; import mx.collections.ArrayCollection; import mx.controls.Alert; import mx.rpc.AsyncResponder; import mx.rpc.Fault; import mx.utils.StringUtil; import spark.components.gridClasses.GridColumn; [Bindable] private var gridSource:ArrayCollection = new ArrayCollection(); [Bindable] private var gridColumns:ArrayCollection = new ArrayCollection(); private var queryTask:QueryTask; protected function onExecuteButtonClick(event:MouseEvent):void { executeQuery(); } private function executeQuery():void { var query:Query = new Query(); query.where = txtWhere.text; query.returnGeometry = false; var outs:Array = StringUtil.trim(txtOuts.text).split(","); query.outFields = outs; queryTask = new QueryTask(txtServiceUrl.text); queryTask.execute(query, new AsyncResponder(onQueryResult, onQueryFault)); } protected function onQueryResult(featureSet:FeatureSet, token:Object = null):void { gridSource = new ArrayCollection(); lblResultsCount.text = StringUtil.substitute("Found: {0} features.", featureSet.features.length); for each(var gr:Graphic in featureSet.features) { gridSource.addItem(gr.attributes); } gridSource.refresh(); gridColumns = new ArrayCollection(); for each (var field:Field in featureSet.fields) { var gridColumn:GridColumn = new GridColumn(field.alias); gridColumns.addItem(gridColumn); } gridColumns.refresh(); } protected function onQueryFault(fault:Fault, token:Object = null):void { trace(fault.getStackTrace()); Alert.show("Query faults.", "Error"); } protected function onGetLastResults(event:MouseEvent):void { if (queryTask && queryTask.executeLastResult) // != null { var results:Array = queryTask.executeLastResult.attributes; var messgae:String = StringUtil.substitute("Last results length is {0}", results.length); Alert.show(messgae, "Message"); } else { Alert.show("Query task is null or has no results!", "Warning"); } } ]]> </fx:Script> <s:Panel width="100%" title="Query parameters"> <s:VGroup gap="5" paddingLeft="5" paddingTop="5" paddingRight="5" paddingBottom="5" width="100%"> <s:HGroup width="100%"> <s:Label text="Url:" width="150" /> <s:TextInput id="txtServiceUrl" width="100%" text="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5" /> </s:HGroup> <s:HGroup width="100%"> <s:Label text="Where clause:" width="150" /> <s:TextInput id="txtWhere" width="100%" text="1=1" /> </s:HGroup> <s:HGroup width="100%"> <s:Label text="Out fields (CSV):" width="150" /> <s:TextInput id="txtOuts" width="100%" text="STATE_NAME,STATE_FIPS,SUB_REGION,STATE_ABBR,POP2000,POP2007" /> </s:HGroup> <s:HGroup width="100%"> <s:Button label="Execute" click="onExecuteButtonClick(event)" /> <s:Button label="Last result length" click="onGetLastResults(event)" /> </s:HGroup> </s:VGroup> </s:Panel> <s:Panel title="Results" width="100%" height="100%"> <s:VGroup gap="5" paddingLeft="5" paddingTop="5" paddingRight="5" paddingBottom="5" width="100%" height="100%"> <s:Label id="lblResultsCount" /> <s:DataGrid width="100%" height="100%" dataProvider="{gridSource}" columns="{gridColumns}"/> </s:VGroup> </s:Panel> </s:Application>
