package ee { import flash.events.Event; import flash.events.EventDispatcher; [Event(name="onDataChanged", type="flash.events.Event")] [Bindable] public class TransferDataManager extends EventDispatcher { public static const TRANSFER_DATA_CHANGED:String = "onDataChanged"; private static var _instance:TransferDataManager; /** * @private */ public function TransferDataManager(caller:Function = null) { if (caller != hidden) throw new Error ("TransferDataManager is a singleton class, use getInstance() instead"); if (_instance != null) throw new Error("Only one Singleton instance should be instantiated"); } /** * @return instance of ResourcesManager * */ public static function getInstance():TransferDataManager { if(!_instance) { _instance = new TransferDataManager(hidden); } return _instance; } /** * @private */ private static function hidden():void {} public var transferedData:Object = null; public function updateTransferData(obj:Object = null):void { transferedData = obj; dispatchEvent(new Event(TRANSFER_DATA_CHANGED)); } } }
<!--- Main application container. --> <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" width="100%" height="100%" preinitialize="group1_preinitializeHandler(event)" ... protected function group1_preinitializeHandler(event:FlexEvent):void { initDataManager(); } [Bindable] private var transferManager:TransferDataManager; protected function initDataManager():void { trace("ViewerContainer::initDataManager()"); transferManager = TransferDataManager.getInstance(); }
<?xml version="1.0" encoding="utf-8"?> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:viewer="com.esri.viewer.*" preinitialize="basewidget1_preinitializeHandler(event)"> <fx:Script> <![CDATA[ import ee.TransferDataManager; import mx.events.FlexEvent; [Bindable] private var transferManager:TransferDataManager; protected function button1_clickHandler(event:MouseEvent):void { trace("SenderWidget::button1_clickHandler()"); // create some data you wand to pass var transferData:Object = new Object(); transferData.message = txtInput.text; transferData.date = new Date(); // get transfer manager instance transferManager = TransferDataManager.getInstance(); transferManager.updateTransferData(transferData); } protected function basewidget1_preinitializeHandler(event:FlexEvent):void { initDataManager(); } protected function initDataManager():void { trace("SenderWidget::initDataManager()"); transferManager = TransferDataManager.getInstance(); transferManager.addEventListener(TransferDataManager.TRANSFER_DATA_CHANGED, onTransferDataChanged); } protected function onTransferDataChanged(event:Event):void { trace("SenderWidget::onTransferDataChanged()"); } ]]> </fx:Script> <viewer:WidgetTemplate id="senderWidget" width="300" height="300"> <viewer:layout> <s:VerticalLayout horizontalAlign="center" verticalAlign="middle"/> </viewer:layout> <s:TextInput id="txtInput" /> <s:Button label="Send" click="button1_clickHandler(event)" /> </viewer:WidgetTemplate> </viewer:BaseWidget>
<?xml version="1.0" encoding="utf-8"?> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:viewer="com.esri.viewer.*" preinitialize="basewidget1_preinitializeHandler(event)"> <fx:Script> <![CDATA[ import ee.TransferDataManager; import mx.events.FlexEvent; import mx.utils.StringUtil; [Bindable] private var transferManager:TransferDataManager; protected function basewidget1_preinitializeHandler(event:FlexEvent):void { trace("RecieverWidget::basewidget1_preinitializeHandler()"); initDataManager(); } protected function initDataManager():void { trace("RecieverWidget::initDataManager()"); transferManager = TransferDataManager.getInstance(); transferManager.addEventListener(TransferDataManager.TRANSFER_DATA_CHANGED, onTransferDataChanged); var transferedData:Object = transferManager.transferedData; if (transferedData) { if (transferedData.hasOwnProperty("message") && transferedData.hasOwnProperty("date")) { var msg:String = StringUtil.substitute("{0} -> {1}", transferedData.message, transferedData.date); writeLog(msg); } } } protected function onTransferDataChanged(event:Event):void { trace("RecieverWidget::onTransferDataChanged()"); transferManager = TransferDataManager.getInstance(); var transferedData:Object = transferManager.transferedData; if (transferedData) { if (transferedData.hasOwnProperty("message") && transferedData.hasOwnProperty("date")) { var msg:String = StringUtil.substitute("{0} -> {1}", transferedData.message, transferedData.date); writeLog(msg); } } } private function writeLog(message:String):void { trace("RecieverWidget::writeLog()"); log.text = StringUtil.substitute("{0}\n{1}", message, log.text); } ]]> </fx:Script> <viewer:WidgetTemplate id="recieverWidget" width="300" height="300"> <viewer:layout> <s:VerticalLayout horizontalAlign="center" verticalAlign="middle"/> </viewer:layout> <s:TextArea width="100%" height="100%" id="log" /> </viewer:WidgetTemplate> </viewer:BaseWidget>
IBaseWidget.as BaseWidget.as WidgetManager.mxml HeaderControllerWidget.mxml
/*IBaseWidget.as*/ /* custom attributes */ function set widgetAttributes(value:Object):void; function get widgetAttributes():Object; ***********----------------------------------******************* /*BaseWidget.as*/ [Bindable] private var _widgetAttributes:Object; //---------------------------------- // widget attributes //---------------------------------- public function get widgetAttributes():Object { return _widgetAttributes; } /** * Set widget additional attributes. * * @param value the object. */ public function set widgetAttributes(value:Object):void { _widgetAttributes = value; } /*WidgetManager.mxml*/ private function runWidget(attributes:Object):void { var widgetId:Number = attributes.id as Number; var widget:IBaseWidget = createWidget(widgetId); widget.widgetAttributes = attributes; openWidget(widget); } private function onRunWidget(event:AppEvent):void { var attributes:Object = event.data as Object; var id:Number = attributes.id as Number; var idx:Object = configData.widgetIndex[id]; var wgtContainer:IWidgetContainer = configData.widgetContainers[idx.container].container.obj; var wgt:Object = configData.widgetContainers[idx.container].widgets[idx.widget]; if (!widgetAdded) { widgetAdded = true; } //widget loaded var widget:IBaseWidget; if (widgetTable.containsKey(id)) { widget = widgetTable.find(id) as IBaseWidget; widget.widgetAttributes = attributes; //add back the container if exists widget.setState(WidgetStates.WIDGET_OPENED); wgtContainer.addWidget(widget); } else { //module loaded if (moduleTable.containsKey(wgt.url)) { runWidget(attributes); } else { loadWidget(attributes); } } } private function loadWidget(attributes:Object):void { var id:Number = 0; if (attributes != null && attributes.hasOwnProperty("id")) { id = attributes.id as Number; } else if (attributes is Number) { id = Number(attributes); } var idx:Object = configData.widgetIndex[id]; var wgt:Object = configData.widgetContainers[idx.container].widgets[idx.widget]; var preload:String = wgt.preload; var url:String = wgt.url; wgtInfo = ModuleManager.getModule(url); wgtInfo.data = { id: id, preload: preload, attributes: attributes }; wgtInfo.addEventListener(ModuleEvent.READY, widgetReadyHandler); wgtInfo.addEventListener(ModuleEvent.ERROR, moduleErrorHandler); wgtInfo.load(null, null, null, moduleFactory); this.cursorManager.setBusyCursor(); } private function preloadNextWidget():void { if (preloadArray.length > 0) { var id:Number = preloadArray[0].id; preloadArray.splice(0, 1); var attr:Object = new Object(); attr.id = id; AppEvent.dispatch(AppEvent.WIDGET_RUN, attr); } } private function widgetReadyHandler(event:ModuleEvent):void { this.cursorManager.removeBusyCursor(); var moduleInfo:IModuleInfo = event.module; moduleTable.add(moduleInfo.url, moduleInfo); var attr:Object = info.data as Object; runWidget(attr); } /* HeaderControllerWidget.mxml */ private function widgetItemDG_widgetItemClickHandler(event:Event):void { var widgetItem:WidgetItem = ItemRenderer(event.target).data as WidgetItem; if (widgetItem.isGroup) { groupWidgetArrCol = new ArrayCollection(); // check the array of widgets if they are open before hand for each (var widgetObj:Object in widgetItem.widgets) { var widgetItem1:WidgetItem = new WidgetItem; widgetItem1.id = widgetObj.widget.id; widgetItem1.label = widgetObj.widget.label; widgetItem1.icon = widgetObj.widget.icon; widgetItem1.url = widgetObj.widget.url; widgetItem1.open = widgetObj.open; groupWidgetArrCol.addItem(widgetItem1); } menuToolTip.visible = false; widgetList.visible = true; } else { var attr:Object = new Object(); attr.id = widgetItem.id; AppEvent.dispatch(AppEvent.WIDGET_RUN, attr); } } private function widgetList_widgetItemClickHandler(event:Event):void { var widgetItem:WidgetItem = ItemRenderer(event.target).data as WidgetItem; var attr:Object = new Object(); attr.id = widgetItem.id; AppEvent.dispatch(AppEvent.WIDGET_RUN, attr); }
