I have a query task that then populates a datagrid with the results. I'd like to be able to zoom to a particular feature when it's clicked on in the datagrid using the SelectionChanged event; (I'm using selectionchanged rather than the mousedown event because I'm doing this as an add-in to the Silverlight Viewer, and mousedown doesn't work; I've posted this to the Viewer forum as well, but sometimes in the past I've had more response in this forum.) I have it working with the results from a FindTask, using the findresult, but I can't quite figure out how to make it work with QueryTask and FeatureSet. Can anyone help? I've included the code below for the FindTask code, but I haven't been able to correctly alter it to work for the Query results.private void FindResults_SelectionChanged(object sender, SelectionChangedEventArgs e) { // Highlight the graphic feature associated with the selected row DataGrid dataGrid = sender as DataGrid;int selectedIndex = dataGrid.SelectedIndex; if (selectedIndex > -1) { FindResult findResult = (FindResult)resultsDataGrid.SelectedItem; Graphic graphic = findResult.Feature; ESRI.ArcGIS.Client.Geometry.Envelope selectedFeatureExtent = findResult.Feature.Geometry.Extent;ESRI.ArcGIS.Client.Geometry.Envelope displayExtent = new ESRI.ArcGIS.Client.Geometry.Envelope( selectedFeatureExtent.XMin - 500, selectedFeatureExtent.YMin - 500, selectedFeatureExtent.XMax + 500, selectedFeatureExtent.YMax + 500);MapApplication.Current.Map.ZoomTo(displayExtent);string StrGeometry = findResult.Feature.Geometry.GetType().ToString();if (StrGeometry.Equals("ESRI.ArcGIS.Client.Geometry.MapPoint")) { graphic.Symbol = Circle; }if (StrGeometry.Equals("ESRI.ArcGIS.Client.Geometry.Polygon")) { graphic.Symbol = Fill; }if (StrGeometry.Equals("ESRI.ArcGIS.Client.Geometry.Polyline")) { graphic.Symbol = YellowLine; }GraphicsLayer graphicsLayer = MapApplication.Current.Map.Layers["MyGraphicsLayer"] as GraphicsLayer; graphicsLayer.ClearGraphics();graphicsLayer.Graphics.Add(graphic);}}
