When I run the following script it just spins and spins then arcmap turns to "not responding". I'm trying to update a versioned parcel layer using a .mdb file. When I "quote" out the updatecursor everything seems to run fine and it seems to enter the edit session as well. Any ideas on what it could be? I'm stuck.
from time import strftime
print "Start script: " + strftime("%Y-%m-%d %H:%M:%S")
import arcpy
from arcpy import env
sourceFC = r'M:\ParcelDatabase\...\Feb_2016_Ownership'
sourceFieldsList = ["PARCEL","SITUS", "CURRENT_OWNER", "CO_OWNER", "OWNER_MAILADDR", "OWNER_CITY_STATE", "OWNER_ZIPCODE", "TAX_DISTRICT", "TAX_CODE", "SEC", "TOWNSHIP", "RANGE", "LEGAL"]
# Use list comprehension to build a dictionary from a da SearchCursor
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sourceFC, sourceFieldsList)}
arcpy.env.workspace = r"Database Connections\parcelpubdelete.sde"
updateFC = r"Database Connections\...\ArcGISSDE.SDE.TaxParcel"
updateFieldsList = ['PARCELID','SITEADDRESS','OWNERNME1', 'OWNERNME2', 'PSTLADDRESS', 'PSTLCITY', 'ZIPCODE', 'TAX_DIST', 'TAX_CODE', 'SEC', 'TWN', 'RGE', 'PRPRTYDSCRP']
edit = arcpy.da.Editor(r"Database Connections\parcelpubdelete.sde")
edit.startEditing(False, True)
edit.startOperation()
print "entered edit session"
with arcpy.da.UpdateCursor(updateFC, updateFieldsList) as updateRows:
for updateRow in updateRows:
# store the Join value of the row being updated in a keyValue variable
keyValue = updateRow[0]
# verify that the keyValue is in the Dictionary
if keyValue in valueDict:
# transfer the values stored under the keyValue from the dictionary to the updated fields.
for n in range (1,len(sourceFieldsList)):
updateRow = valueDict[keyValue][n-1]
updateRows.updateRow(updateRow)
del valueDict
edit.stopOperation()
edit.stopEditing(True)
print "Finished script: " + strftime("%Y-%m-%d %H:%M:%S")
