def Concatenate(field1,field2): if field2 == "": return field1 else: return field1 + '-' + field2
Concatenate(str(!MyField1!), str(!MyField2!))
def myFunction(one,two): if one == "": # check if first field is <null> if two == "": # check if both fields are <null> and returns <null> pass else: return two # otherwise, just return the second field value else: # check if the first field is populated... if two == "": # if second field is blank return one # return just the first field else: # if both fields are populated return one + "-" + two # return a concatenation of the fields with a hyphen deliminator
myFunction(str(!field1!), str(!field2!))
Dim Output If IsNull([MyField2]) Then Output = [MyField1] Elseif Trim([MyField2]) = "" Then Output = [MyField1] Else Output = [MyField1] & "-" & [MyField2] End If
