What's going on?! It was working fine a few days ago. Then suddenly it stopped saving ANYTHING I did in the Web AppBuilder altogether. It would run during the session, but once I closed the browser nothing I had saved would be saved. So I deleted Web AppBuilder, downloaded a new copy, UNREGISTERED and RE-REGISTERED the App... did everything like before... and still no love.
I have maps I need to be making... HELP!
Do you have a named user in your organizations Portal? If so, you would want to register it there.
I have seen others that said they have been able to place on a server and share somewhat. I have not try it. I just supplied the links in another post which I will copy here.
other post: Re: Web Appbuilder (developer edition), How to have multiple editors of an app?
other links:
This is a workaround for one developer and multiple non-developer's, not exactly the same but might help.
Re: Custom Widgets as an add-in? the comments by Pascual Benito
There have been other discussions on what you are trying to do This is probably the most precise answer
Re: Sharing Web AppBuilder apps with multiple users
Rebecca,
Is this true? I'm running web app builders for developer on a dev server (well was hoping to) using ArcGIS for Server and Portal. I can't run it on my local machine.
Is this going to cause issues?
I cannot register my apps either which I was thinking was some sort of issue with Portal. I keep getting told my redirect uri is invalid.
However, I have to keep things very locked down in my organization so I cannot run this with AGO.
Carmie
Brian, remember, you should run Web Appbuilder on a user machine, not a server. Once you deploy you will want the deployed site on the server, or a web machine (eg IIS) but fir developmention, it should be installed and run on a desktop. At least reading thru your explaination, it looks lIke its on a arcgis server machine, not local.
Well, on a whim... I remembered that in the "REGISTERED INFO" of the process I USED to have more robust entries. So I entered...
http://servername.main.ourdomain.org:3344/webappbuilder/
to the registered info URI section and voila...
I don't have time today to see if it will let me save... but at least it's opening now. UGH! That was an annoying 2 hour ordeal...
I did.
Try setting http://<YourMachineName> and https://<YourMachineName> in the redirect uri while registering the app.
