Your screen shot doesn't match the scenario you're describing...are you sure you're specifying your paths correctly? For instance, you talk about �??/web/scripts/dojo/dojo/dojo.js�?� but your screen shot shows "js/dojo/dojo".How are you specifying your module path? Can you post the code you're using to define your module paths?I recommend reading up on how this works in dojo: http://dojotoolkit.org/reference-guide/dojo/registerModulePath.htmlAlso look into using modulePaths via dojoConfig/djConfig.
if (!dojo._hasResource["custom.config"]) { dojo._hasResource["custom.config"] = true; dojo.provide("custom.config"); dojo.declare("custom.Config", null, { constructor: function(){ } }); dojo.mixin(custom.Config, { configPath: "conf/config.txt", configObj: null, parseConfig: function(load, error){ dojo.xhrGet({ url: this.configPath, handleAs: "json", load: load, error: error }); } }); }
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"> <html> <head> <title>index.html</title> <meta http-equiv="keywords" content="keyword1,keyword2,keyword3"> <meta http-equiv="description" content="this is my page"> <meta http-equiv="content-type" content="text/html; charset=UTF-8"> <!--<link rel="stylesheet" type="text/css" href="./styles.css">--> <link rel="stylesheet" type="text/css" href="css/main.css"> <link rel="stylesheet" type="text/css" href="js/arcgis_js_api/library/2.4/arcgis/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" type="text/css" href="js/arcgis_js_api/library/2.4/arcgis/js/dojo/dojox/grid/resources/claroGrid.css"> <script type="text/javascript" src="js/arcgis_js_api/library/2.4/arcgis/"> </script> <script type="text/javascript"> djConfig = { parseOnLoad: true }; </script> <script type="text/javascript"> dojo.require("esri.map"); dojo.registerModulePath("custom", "../../custom"); dojo.require("custom.config"); //this line throw error.... function init(){ console.log(custom.Config.configPath); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div id="headContainer"> <div id="head"> </div> </div> </body> </html>
dojo.registerModulePath("custom", "http://localhost:8080/cd/js/arcgis_js_api/library/2.4/arcgis/js/custom");
