Hello,I am new to Python, and programming all together really. I am building a model where I want the user to select from a drop down list a value for a parameter (Climate Variable). I then want to use the Calculate Value tool to then get a string value for a variable that will be used to choose a field from a feature attribute table (PYCLIM). I wrote this If Statement (which I believe is wrong) to do such and I am getting the 000989 syntax error on Line 1.def getCLIMVAR(PYCLIM):
climvar = str(%Climate Variable%):
if climvar == "Current Temperature":
PYCLIM = "CUR_TEMP"
return PYCLIM
elif climvar == "High Temperature":
PYCLIM == "HI_TEMP"
return PYCLIM
elif climvar == "Low Temperature":
PYCLIM == "LOW_TEMP"
return PYCLIM
elif climvar == "Wind Chill Temperature":
PYCLIM == "CHILL_TEMP"
return PYCLIM
elif climvar == "Dew Point Temperature":
PYCLIM == "DEW_TEMP"
return PYCLIM
PYCLIM == "HI_TEMP"
return PYCLIM
elif climvar == "Relative Humidty":
PYCLIM == "REL_HUMID"
return PYCLIM
elif climvar == "Solar Radiation":
PYCLIM == "SOL_RAD"
return PYCLIM
elif climvar == "Wind Speed":
PYCLIM == "WIND_SPEED"
return PYCLIM
else climvar == "Highest Wind Gust":
PYCLIM == "HI_WIND_GUS"
return PYCLIM
Any help would be appreciated. Thank you in advance! If the code is horrible, please understand that I wrote this without ANY python experience.
