Any examples out there of allowing the user to type in a lat long and creating a point at that location and/or zooming to it,,,,
Much like the below but with XY not address
Geocode an address | ArcGIS API for JavaScript
I built on the example I gave you, check it out:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Find Address</title> <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { padding: 0; border: solid 2px #666; margin: 0 5px 5px 5px; } #header { border: solid 2px #666; color: #666; font-family: sans-serif; font-size: 1.1em; height: auto; margin: 5px; overflow: hidden; padding: 10px 0 10px 20px; text-align:left; } .roundedCorners { -webkit-border-radius: 5px; -moz-border-radius: 5px; border-radius: 5px; } </style> <script src="http://js.arcgis.com/3.10/"></script> <script> var map; require([ "esri/map", "esri/tasks/locator", "esri/graphic", "esri/geometry/webMercatorUtils", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/InfoTemplate", "esri/Color", "esri/geometry/Point", "dojo/on", "dojo/number", "dojo/parser", "dojo/dom", "dijit/registry", "dijit/form/TextBox", "dijit/form/Button", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, Locator, Graphic, webMercatorUtils, SimpleMarkerSymbol, SimpleLineSymbol, InfoTemplate, Color, Point, on, number, parser, dom, registry, TextBox ) { parser.parse(); map = new Map("map", { basemap: "streets", center: [-95.273, 38.95], zoom: 14 }); var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CIRCLE, 15, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 255, 0.5]), 8 ), new Color([0, 0, 255]) ); var locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"); var infoTemplate = new InfoTemplate("Location", "Address: ${Address}"); locator.on("location-to-address-complete", function(evt) { if (evt.address.address) { var address = evt.address.address; var location = webMercatorUtils.geographicToWebMercator(evt.address.location); //this service returns geocoding results in geographic - convert to web mercator to display on map // var location = webMercatorUtils.geographicToWebMercator(evt.location); var graphic = new Graphic(location, symbol, address, infoTemplate); map.graphics.add(graphic); map.infoWindow.setTitle(graphic.getTitle()); map.infoWindow.setContent(graphic.getContent()); //display the info window with the address information var screenPnt = map.toScreen(location); map.infoWindow.resize(200,100); map.infoWindow.show(screenPnt, map.getInfoWindowAnchor(screenPnt)); } }); map.on("click", function(evt) { map.graphics.clear(); locator.locationToAddress(webMercatorUtils.webMercatorToGeographic(evt.mapPoint), 100); }); var LongTextBox = new TextBox({ placeHolder: "Longitude", value:"-95.273", intermediateChanges:true },"LongTextBoxDiv"); var LatTextBox = new TextBox({ placeHolder: "Latitude", value:"38.95", intermediateChanges:true },"LatTextBoxDiv"); on(registry.byId("latlong"), "click", getaddress); function getaddress(){ var Lat = LatTextBox.get("value"); var Long = LongTextBox.get("value"); var LatLongLocation = new Point([Long,Lat]); locator.locationToAddress(LatLongLocation , 100); map.graphics.clear(); } }); </script> </head> <body class="claro"> <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%; height:100%;"> <div id="header" class="roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'"> Long: <input id="LongTextBoxDiv" /> Lat: <input id="LatTextBoxDiv" /> <button id="latlong" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button">Get Address</button> </div> <div id="map" class="roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
Hope this answers your question!
Tim
I do this and nothing happens..
Also tried getting rid of the _ in your example and still no zooming
var graphicExtent = graphic._extent.getExtent();
Trying this way
var graphicExtent = graphic.extent.getExtent();
Error
TypeError {stack: (...), message: "Cannot read property 'getExtent' of undefined"
var graphic = new Graphic(location, ReverseGeocodesymbol, address, infoTemplateRG);
app.map.graphics.add(graphic);
app.map.infoWindow.setTitle(graphic.getTitle());
app.map.infoWindow.setContent(graphic.getContent());
var screenPnt = app.map.toScreen(location);
app.map.infoWindow.resize(200,100);
app.map.infoWindow.show(screenPnt, app.map.getInfoWindowAnchor(screenPnt));
app.map.setExtent(graphicExtent);
Instead of what you have, add the following:
var graphicExtent = graphic._extent.getExtent(); map.setExtent(graphicExtent);
Hope this helps!
How would I zoom to it?
Would like to zoom to the Graphic being created below
var stateExtent = location [0].geometry.getExtent().expand(5.0); map.setExtent(stateExtent);
You convert it from deg/min/sec and once you have your Lat/Long feed them into line 122, here:
Worked great Tim....thanks...
And thats Jeff....will be revisiting this once I figure out what their preference is.....so if the do degrees minutes seconds...I test for this? Then grab the values from the textboxes and convert them pass to the locator?
You may need this too, depending on if your users want to enter degrees-minutes-seconds:Parse Degrees Minutes Seconds (DMS) into Decimal Degrees
Jay,
you could use this Reverse geocode | ArcGIS API for JavaScript , but instead of a "map on click event" you could create a box, where a user can put in the lat/long, then create a point from that information and use the point as your "evt.mapPoint".
