Can you try using EditorWidget instead of GP tool to add the shape? You can create rings by performing Cut. Try to see if the order of rings is still unpredictable. If no, then maybe the GP tool is causing this?You can also try performing the query from your web browser through the REST end point. Is this off a map service or feature service? I don't know how I could help. I asked the REST API team and they also do not manipulate the order, they simply return geometry as it is returned by service. What version of ArcGIS Server do you have? I'm thinking ArcGIS Server team might be able to assist you but you also might want to contact support and give them a reproducible sample?
Can you check in Fiddler, the request for geometry returns the rings in the same order as you want them drawn? If the query result is already reversed then ArcGIS API for Silverlight have respected the order geometry was received.
