private function showFlood(event:MouseEvent):void { msg = "Loading Flood Zone layer . . . "; PopUpManager.addPopUp(tWindow2, hostComponent.map, true); PopUpManager.centerPopUp(tWindow2); event.stopImmediatePropagation(); ViewerContainer.addEventListener(AppEvent.LAYER_LOADED, layerloadComplete); ViewerContainer.dispatchEvent(new AppEvent(AppEvent.PROGRAMATIC_LAYER_VISIBILITY_CHANGED, "Flood Zones")); var resultEvent:Polygon = new Polygon; geomArr = []; var graphic:Graphic = hostComponent.graphic; geomArr.push(graphic.geometry); var bufferParameters:BufferParameters = new BufferParameters(); bufferParameters.bufferSpatialReference= new SpatialReference(102003); bufferParameters.geometries = geomArr; bufferParameters.unit = GeometryService.UNIT_FOOT; bufferParameters.distances = [ 1 ]; function layerloadComplete(event:AppEvent):void { ViewerContainer.removeEventListener(AppEvent.LAYER_LOADED, layerloadComplete); msg = "Searching for nearest Flood Zone . . . "; beginBuffer(); } function beginBuffer():void { myGeometryService.addEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler); myGeometryService.buffer(bufferParameters); } function bufferCompleteHandler(event:GeometryServiceEvent):void { myGeometryService.removeEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler); resultEvent = event.result[0]; try { var graphic:Graphic = new Graphic(); graphic.geometry = resultEvent; queryFeaturesGraphical(graphic.geometry); } catch (error:Error) { Alert.show(error.message); } } function queryFeaturesGraphical(geom:Geometry):void { var queryParams:Query = new Query(); queryParams.returnGeometry = false; var queryFields:String = "*"; queryParams.outFields = queryFields.split(","); queryParams.geometry = geom; queryParams.where = "FLD_ZONE IN ('A','AE')"; queryParams.spatialRelationship = "esriSpatialRelIntersects"; var url:String = "http://[myserver]/ArcGIS/rest/services/Feature_Natural/MapServer/8"; var queryTask:QueryTask = new QueryTask(url); queryTask.execute(queryParams, new AsyncResponder(onResult, onFault)); } function onResult(featureSet:FeatureSet, token:XMLList = null):void { try { if (featureSet.features.length < 1) { if (bufferParameters.distances[0].toString() == "5280") { msg = "The nearest Flood Zone is more than a mile away."; } if (bufferParameters.distances[0].toString() == "2640") { msg = "The nearest Flood Zone is more than a half mile away."; bufferParameters.distances = [ 5280 ]; beginBuffer(); } if (bufferParameters.distances[0].toString() == "1000") { msg = "The nearest Flood Zone is more than 1000 feet away."; bufferParameters.distances = [ 2640 ]; beginBuffer(); } if (bufferParameters.distances[0].toString() == "500") { msg = "The nearest Flood Zone is more than 500 feet away."; bufferParameters.distances = [ 1000 ]; beginBuffer(); } if (bufferParameters.distances[0].toString() == "200") { msg = "The nearest Flood Zone is more than 200 feet away."; bufferParameters.distances = [ 500 ]; beginBuffer(); } if (bufferParameters.distances[0].toString() == "1") { msg = "This property is touching or inside a Flood Zone."; bufferParameters.distances = [ 200 ]; beginBuffer(); } } else { for each(var obj:Object in featureSet.attributes){ Alert.show("done"); break; } } } catch (error:Error) { Alert.show(error.message); } } function onFault(info:Object, token:Object = null):void { Alert.show(info.toString()); } }
