import arcpy def numberStringFieldsWithLayer(layer = None): # If no layer is passed in, stop the function if layer == None: return None # Get the count for each field with type "String" n = 0 for field in arcpy.ListFields(layer): if field.type == "String": n += 1 return n
# Add your custom module folder to the system paths import sys sys.path.append(r"Path\to\your\custom\module\folder") # import your custom moudle import customModule # Make a layer object from your feature layer streetsLayer = arcpy.mapping.Layer("streets") # Call you custom function from the module numberOfFieldsTypeString = customModule.numberStringFieldsWithLayer(streetsLayer) # Remove your layer reference del streetsLayer # Print your results print numberOfFieldsTypeString
Here's a very simple way to call another script (there are many other ways):
