thank you or all the sharing up here. all i need is a .net barcode scanner component, of course , asp.net barcode scanner would be better. i am now very familiar with C# and VB.NET. so any suggestion on how to create this barcode scanner with these two language. i want to make my own, thank you.
I know a good barcode solution site. Here share it with you all. I hope it would be helpful for someone. It's called onbarcode. You can rich barcode generators and barcode readers there, like barcode reader for iPhone, barcode reader for Java, Java Class barcode generator library, and C# ASP.NET barcode generator library, etc. I believe you guys can find your barcode solutions there. I have been using the tools from this site for years.
Hi, I am very interested in this as well, because we have a project coming up where we will be using a Geo XH to collect meter pit data, and the meters have barcodes. So we want to use a scanner to speed up the process, and to eliminate typo errors. Does anyone have advice on which scanners seem to work well with Trimble units running arcpad? Or any pitfalls to be aware of? Eric
hello there is an application called barcode 2 sql in app store. Free source to download. it scan the barcode and stores data in a database...for more information check www.barcode2sql.com hope it might be helpful 😉
