Hallo allemaal,<\/P>
<\/P>
Wat raden jullie aan bij het bewerken van GIS-lagen met Web App Builder en SDE, versiebeheerde of niet-versiebeheerde lagen?<\/P>
Bedankt<\/P><\/BODY><\/HTML>
Jose,
If you are not currently doing any versioning then you are more than likely safe just editing the default version.
Thanks Robert!
For layers that are going to be edited only on the web, do you recommend to edit in the Default SDE or to create a version and edit the child version.
Versioning is required for a FeatureService which is what JS API need to use to edit data.
Well, with ArcMAp you can edit an SDE layer that is not versioned.
https://desktop.arcgis.com/en/arcmap/10.3/manage-data/geodatabases/configuring-an-arcmap-edit-session-to-perform-nonversioned-edits.htm
You can not do any editing of a SDE GIS Layer without having it versioned.
