Credentials can be defined by the proxy administrator for both token and Windows/HTTP secured services.
[...] this will not work in WPF [...].
Could you please post that code?
public class ProxyServer { private static readonly string THIS_PROXY_ADDRESS = "http://localhost"; private static readonly int THIS_PROXY_PORT = 51212; private static readonly int BUFFER_SIZE = 8192; private static readonly char[] semiSplit = new char[] { ';' }; private static readonly char[] equalSplit = new char[] { '=' }; private static readonly String[] colonSpaceSplit = new string[] { ": " }; private static readonly char[] spaceSplit = new char[] { ' ' }; private static readonly char[] commaSplit = new char[] { ',' }; private static readonly Regex cookieSplitRegEx = new Regex(@,(?! )); private static object _outputLockObj = new object(); private TcpListener _listener; private Thread _listenerThread; private IWebProxy realProxy; private IWebProxy thisProxy; private ICredentials realProxyCredentials; public ProxyServer() { realProxy = HttpWebRequest.GetSystemWebProxy(); realProxyCredentials = CredentialCache.DefaultCredentials; thisProxy = new WebProxy() { Address = new Uri(THIS_PROXY_ADDRESS + ":" + THIS_PROXY_PORT + @/), }; _listener = new TcpListener(ListeningIPInterface, ListeningPort); this.DumpHeaders = false; this.DumpPostData = false; this.DumpResponseData = false; } public ProxyServer(IWebProxy proxy, ICredentials credentials) { realProxy = proxy; realProxyCredentials = credentials; thisProxy = new WebProxy() { Address = new Uri(THIS_PROXY_ADDRESS + ":" + THIS_PROXY_PORT + @/), }; _listener = new TcpListener(ListeningIPInterface, ListeningPort); this.DumpHeaders = false; this.DumpPostData = false; this.DumpResponseData = false; } public IWebProxy Proxy { get { return thisProxy; } } public IPAddress ListeningIPInterface { get { IPAddress addr = IPAddress.Loopback; return addr; } } public Int32 ListeningPort { get { Int32 port = THIS_PROXY_PORT; return port; } } public Boolean DumpHeaders { get; set; } public Boolean DumpPostData { get; set; } public Boolean DumpResponseData { get; set; } public bool Start() { try { _listener.Start(); } catch (Exception ex) { Console.WriteLine(ex.Message); return false; } _listenerThread = new Thread(new ParameterizedThreadStart(Listen)); _listenerThread.Start(_listener); return true; } public void Stop() { _listener.Stop(); //wait for server to finish processing current connections... _listenerThread.Abort(); _listenerThread.Join(); _listenerThread.Join(); } private void Listen(Object obj) { TcpListener listener = (TcpListener)obj; try { while (true) { TcpClient client = listener.AcceptTcpClient(); while (!ThreadPool.QueueUserWorkItem(new WaitCallback(ProcessClient), client)) ; } } catch (ThreadAbortException) { } catch (SocketException) { } } private void ProcessClient(Object obj) { TcpClient client = (TcpClient)obj; try { DoHttpProcessing(client); } catch (Exception ex) { Console.WriteLine(ex.Message); } finally { client.Close(); } } private void DoHttpProcessing(TcpClient client) { Stream clientStream = client.GetStream(); Stream outStream = clientStream; //use this stream for writing out - may change if we use ssl StreamReader clientStreamReader = new StreamReader(clientStream); //if (this.DumpHeaders || this.DumpPostData || this.DumpResponseData) //{ // //make sure that things print out in order - NOTE: this is bad for performance // Monitor.TryEnter(_outputLockObj, TimeSpan.FromMilliseconds(-1.0)); //} try { //read the first line HTTP command String httpCmd = clientStreamReader.ReadLine(); if (String.IsNullOrEmpty(httpCmd)) { clientStreamReader.Close(); clientStream.Close(); return; } //break up the line into three components String[] splitBuffer = httpCmd.Split(spaceSplit, 3); String method = splitBuffer[0]; String remoteUri = splitBuffer[1]; if (remoteUri.Substring(0, 2).Equals("/?")) { remoteUri = remoteUri.Substring(2); } remoteUri = Uri.UnescapeDataString(remoteUri); HttpWebRequest webReq; HttpWebResponse response = null; //construct the web request that we are going to issue on behalf of the client. webReq = (HttpWebRequest)HttpWebRequest.Create(remoteUri); webReq.Method = method; //webReq.ProtocolVersion = version; //read the request headers from the client and copy them to our request int contentLen = ReadRequestHeaders(clientStreamReader, webReq); webReq.Proxy = realProxy; webReq.Proxy.Credentials = realProxyCredentials; webReq.KeepAlive = false; //webReq.AllowAutoRedirect = false; //webReq.AutomaticDecompression = DecompressionMethods.None;
if (this.DumpHeaders) { Console.WriteLine(String.Format("{0} {1} HTTP/{2}", webReq.Method, webReq.RequestUri.AbsoluteUri, webReq.ProtocolVersion)); DumpHeaderCollectionToConsole(webReq.Headers); } //Console.WriteLine(String.Format("ThreadID: {2} Requesting {0} on behalf of client {1}", webReq.RequestUri, client.Client.RemoteEndPoint.ToString(), Thread.CurrentThread.ManagedThreadId)); webReq.Timeout = 15000; try { response = (HttpWebResponse)webReq.GetResponse(); } catch (WebException webEx) { response = webEx.Response as HttpWebResponse; } if (response != null) { List<Tuple<String,String>> responseHeaders = ProcessResponse(response); StreamWriter myResponseWriter = new StreamWriter(outStream); Stream responseStream = response.GetResponseStream(); try { //send the response status and response headers WriteResponseStatus(response.StatusCode, response.StatusDescription, myResponseWriter); WriteResponseHeaders(myResponseWriter, responseHeaders); Byte[] buffer; if (response.ContentLength > 0) buffer = new Byte[response.ContentLength]; else buffer = new Byte[BUFFER_SIZE]; int bytesRead; while ((bytesRead = responseStream.Read(buffer, 0, buffer.Length)) > 0) { outStream.Write(buffer, 0, bytesRead); if (this.DumpResponseData) Console.Write(UTF8Encoding.UTF8.GetString(buffer, 0, bytesRead)); } if (this.DumpResponseData) { Console.WriteLine(); Console.WriteLine(); } responseStream.Close(); outStream.Flush(); } catch (Exception ex) { Console.WriteLine(ex.Message); } finally { responseStream.Close(); response.Close(); myResponseWriter.Close(); } } } catch (Exception ex) { Console.WriteLine(ex.Message); } finally { if (this.DumpHeaders || this.DumpPostData || this.DumpResponseData) { //release the lock Monitor.Exit(_outputLockObj); } clientStreamReader.Close(); clientStream.Close(); outStream.Close(); } } private static List<Tuple<String, String>> ProcessResponse(HttpWebResponse response) { String value=null; String header=null; List<Tuple<String, String>> returnHeaders = new List<Tuple<String, String>>(); foreach (String s in response.Headers.Keys) { if (s.ToLower() == "set-cookie") { header = s; value = response.Headers; } else returnHeaders.Add(new Tuple<String, String>(s, response.Headers)); } if (!String.IsNullOrWhiteSpace(value)) { response.Headers.Remove(header); String[] cookies = cookieSplitRegEx.Split(value); foreach (String cookie in cookies) returnHeaders.Add(new Tuple<String, String>("Set-Cookie", cookie)); } //returnHeaders.Add(new Tuple<String, String>("X-Proxied-By", "esri-application proxy")); return returnHeaders; } private void WriteResponseStatus(HttpStatusCode code, String description, StreamWriter myResponseWriter) { String s = String.Format("HTTP/1.0 {0} {1}", (Int32)code, description); myResponseWriter.WriteLine(s); if (this.DumpHeaders) Console.WriteLine(s); } private void WriteResponseHeaders(StreamWriter myResponseWriter, List<Tuple<String, String>> headers) { if (headers != null) { foreach (Tuple<String,String> header in headers) myResponseWriter.WriteLine(String.Format("{0}: {1}", header.Item1, header.Item2)); } myResponseWriter.WriteLine(); myResponseWriter.Flush(); if (this.DumpHeaders) DumpHeaderCollectionToConsole(headers); } private static void DumpHeaderCollectionToConsole(WebHeaderCollection headers) { foreach (String s in headers.AllKeys) Console.WriteLine(String.Format("{0}: {1}", s, headers)); Console.WriteLine(); } private static void DumpHeaderCollectionToConsole(List<Tuple<String, String>> headers) { foreach (Tuple<String,String> header in headers) Console.WriteLine(String.Format("{0}: {1}", header.Item1, header.Item2)); Console.WriteLine(); } private static int ReadRequestHeaders(StreamReader sr, HttpWebRequest webReq) { String httpCmd; int contentLen = 0; do { httpCmd = sr.ReadLine(); if (String.IsNullOrEmpty(httpCmd)) return contentLen; String[] header = httpCmd.Split(colonSpaceSplit, 2, StringSplitOptions.None); switch (header[0].ToLower()) { case "host": // since HttpWebRequests correctly add the "Host" property anyway, and the // requests from the ArcGIS WPF API change the "Host" to the ProxyURL, we // don't want to set that here. It will just end in tears, I know it. //webReq.Host = header[1]; break; case "user-agent": webReq.UserAgent = header[1]; break; case "accept": webReq.Accept = header[1]; break; case "referer": webReq.Referer = header[1]; break; case "cookie": webReq.Headers["Cookie"] = header[1]; break; case "proxy-connection": case "connection": case "keep-alive": //ignore these break; case "content-length": int.TryParse(header[1], out contentLen); break; case "content-type": webReq.ContentType = header[1]; break; case "if-modified-since": String[] sb = header[1].Trim().Split(semiSplit); DateTime d; if (DateTime.TryParse(sb[0], out d)) webReq.IfModifiedSince = d; break; default: try { webReq.Headers.Add(header[0], header[1]); } catch (Exception ex) { Console.WriteLine(String.Format("Could not add header {0}. Exception message:{1}", header[0], ex.Message)); } break; } } while (!String.IsNullOrWhiteSpace(httpCmd)); return contentLen; } }
IWebProxy webProxy = WebRequest.GetSystemWebProxy(); webProxy.Credentials = new NetworkCredential("<username>", "<password>"); WebRequest.DefaultWebProxy = webProxy;
WebRequest.DefaultWebProxy = new WebProxy("http://<myProxyHost>:<myProxyPort>", true) // secong arg=true to bypass on local { Credentials = new NetworkCredential("<username>", "<password>") };
WebRequest.RegisterPrefix("http://www.arcgis.com", new WebRequestCreateThroughProxy()); public class WebRequestCreateThroughProxy : IWebRequestCreate { private static readonly WebProxy _webProxy; static WebRequestCreateThroughProxy() { _webProxy = new WebProxy("http://<myProxyHost>:<myProxyPort>", true) { Credentials = new NetworkCredential("<username>", "<password>") }; } public WebRequest Create(Uri uri) { var webRequest = WebRequest.CreateHttp(uri); webRequest.Proxy = _webProxy; return webRequest; } }
<system.net> <defaultProxy enabled="true" useDefaultCredentials="true"/> </system.net>
Hi Loren,
I seem to be running into this same issue. Would you mind sharing your updated code with me?
