Is your networking 128 kiloBITS/sec or 128 kiloBYTES/sec? Frequency of update is the other big factor. It's certainly possible to do change detection as a application solution,but doing ...... How much time do you haveto dedicate to getting this solution working?- V
ArcGIS replication uses versioning. If your layer gets completely replacedwith each update, you should consider using a different update methodology.Then again, 100 features is a trivial number, so the bandwidth and processingcost is negligible.I would recommend that if you want to use replication, that you use it perdesign (edit the existing table), rather than breaking the replication by dropping and re-adding the feature class.- V
