Hi Guys,
I ma looking for JavaScript sample to split/cur polyline in ArcGis JavaScript API.
I found one sample but it did not work for me.
I tried to do something using Geometry but failed.
If you have some code share Please.
Thank you.
Could you explain a bit more about what you are trying to accomplish, and post the code that you tried? Also, which version of the JS API are you using?
I would create a geo - processing(python) tool like erase on the server and host it.
Once hosted I will call the tool in my javascript code.
Here is the python tool box code:
import arcpyfrom arcpy import envenv.workspace=sys.path[0]+"/test.gdb"env.overwriteOutput=True
class Toolbox(object): def __init__(self): """Define the toolbox (the name of the toolbox is the name of the .pyt file).""" self.label = "Toolbox" self.alias = ""
# List of tool classes associated with this toolbox self.tools = [_Erase]
class Model_Erase(object): def __init__(self): """Define the tool (tool name is the name of the class).""" self.label = "_Erase" self.description = "" self.canRunInBackground = False
def getParameterInfo(self): # Input Features parameter Input_Feature_Line = arcpy.Parameter( displayName="Input Feature", name="Input_Feature_Line", datatype="DEFeatureClass", parameterType="Required", direction="Input") Input_Feature_Line.filter.list = ["Point","Polyline","Polygon"]
Input_Erase_Layer = arcpy.Parameter( displayName="Erase Feature", name="Input_Erase_Layer", datatype="DEFeatureClass", parameterType="Required", direction="Input") Input_Erase_Layer.filter.list = ["Point","Polyline","Polygon"]
Output_Feature_Layer = arcpy.Parameter( displayName="Intersect Output", name="Intersect_Layer", datatype="GPFeaturelayer", parameterType="Derived", direction="Output")
parameters = [Input_Feature_Line, Input_Erase_Layer,Output_Feature_Layer] return parameters
def isLicensed(self): """Set whether tool is licensed to execute.""" arcpy.CheckOutExtension("Spatial") return True
def updateParameters(self, parameters): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parameter has been changed.""" return
def updateMessages(self, parameters): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return
def execute(self, parameters, messages): """The source code of the tool.""" Input_Feature_Line = parameters[0].valueAsText Input_Erase_Layer = parameters[1].valueAsText if Input_Feature_Line == '#' or not Input_Feature_Line: Input_Feature_Line = sys.path[0]+"/test.gdb/polygon_area_buffer_1" # provide a default value if unspecified
if Input_Erase_Layer == '#' or not Input_Erase_Layer: Input_Erase_Layer = sys.path[0]+"/test.gdb/Deployment" # provide a default value if unspecified
# Local variables: #out_feature_class="%SCRATCHWORKSPACE%\\Erase_output.shp" out_feature_class="in_memory/out_feature_class" cluster_tolerance = "#" # Process: Erase arcpy.Erase_analysis(Input_Feature_Line, Input_Erase_Layer, out_feature_class, cluster_tolerance) parameters[2].value = out_feature_class print "DONE" return
Sorry, not sure how to help. It would be helpful to share your JavaScript code, JS API version, and any Console error messages.
Hi Guys, need a time, start working on Python Add-in, when finish i will share Code.
