Start Time: Wed Apr 13 11:32:31 2011 ERROR 010160: Unable to open raster t_t966\t_t966. Zonal statistics program failed ERROR 010067: Error in executing grid expression. Failed to execute (Zonal Statistics as Table).
function computeZonalStats(geometry) { /*After user draws shape on map using the draw toolbar compute the zonal*/ map.showZoomSlider(); map.graphics.clear(); var symbol = new esri.symbol.SimpleFillSymbol("none", new esri.symbol.SimpleLineSymbol("dashdot", new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25])); var graphic = new esri.Graphic(geometry,symbol); map.graphics.add(graphic); toolbar.deactivate(); var features= []; features.push(graphic); var featureSet = new esri.tasks.FeatureSet(); featureSet.features = features; var params = {}; params.inputPoly = featureSet; gp.execute(params, displayResults, errorStatus); }
I am certain the json payload is being built ok because I have copied and used in on one of ESRI's samples and it works. Here it is decoded:{"geometryType":"esriGeometryPolygon","features": [{"geometry":{"rings":[[[-12035713.324158048,4906523.155443832],[-12006361.505296549,4886955.276202832],[-12035713.324158048,4877171.336582333],[-12035713.324158048,4906523.155443832]]],"spatialReference":{"wkid":102100}}}],"sr":{"wkid": 102100}}Also, here is an error Im getting in the logs. The grid does have a .vat so that isn't the problem.<Msg time='2011-04-11T15:40:16' type='ERROR' code='20010' target='tmtools/zonal.GPServerSync' methodName='GPServerSync.CheckMessages' machine='IGSKAECGAS010' process='4936' thread='1504'>Executing (SumZone): ZonalStatsSum "Feature Set" in_memory\results Start Time: Mon Apr 11 15:40:16 2011 Executing (Zonal Statistics as Table): ZonalStatisticsAsTable "Feature Set" Id c:\arcgisserver\sumzone\grid.gdb\picall_wmb in_memory\results DATA SUM Start Time: Mon Apr 11 15:40:16 2011 ERROR 010160: Unable to open raster t_t3626\t_t3626. Zonal statistics program failed ERROR 010067: Error in executing grid expression. Failed to execute (Zonal Statistics as Table). Failed at Mon Apr 11 15:40:16 2011 (Elapsed Time: 0.00 seconds) Failed to execute (SumZone). Failed at Mon Apr 11 15:40:16 2011 (Elapsed Time: 0.00 seconds)</Msg><Msg time='2011-04-11T15:40:16' type='ERROR' code='20010' target='tmtools/zonal.GPServerSync' methodName='GPServerSync.CheckMessages' machine='IGSKAECGAS010' process='4936' thread='1504'>Error executing tool.: ERROR 010160: Unable to open raster t_t3626\t_t3626. Zonal statistics program failed ERROR 010067: Error in executing grid expression. Failed to execute (Zonal Statistics as Table). Failed to execute (SumZone).</Msg>
We have a geoprocessing service running in ArcGIS Server 10 sp1 java edition. It is basically the same as the population summary/demographics GP Example.The geoprocessing service runs fine in ArcMap and in ArcGIS Explorer as a service from ArcGIS Server.When trying to implement the service within a web app using the javascript api based on this sample http://help.arcgis.com/en/webapi/javascript/arcgis/demos/gp/gp_zonalstats.html (and even with the flex sample) I keep getting "dojo.io.script.jsonp_dojoIoScript2._jsonpCallback({"error":{"code":500,"message":"Error executing task 'SumZone'. Please check your parameters.","details":[]}});"We have tried everything1. Running it locally2. local jobs folder, etc3. Both on 9.3.1 and 10Here is the REST request with the geometry payload to execute the servicehttp://igskaecgas010:8399/arcgis/rest/services/tmtools/ZonalStats/GPServer/SumZone/execute?f=json&env:outSR=102100&env:processSR=102100&inputPoly={"geometryType":"esriGeometryPolygon","features":[{"geometry":{"rings":[[[-12089524.992070802,4855463.220549357],[-12083410.029807992,4851488.49507853],[-12084021.526034273,4851488.49507853],[-12086773.259052537,4851488.49507853],[-12089524.992070802,4849654.006399686],[-12089524.992070802,4853017.2356442325],[-12089524.992070802,4855463.220549357]]],"spatialReference":{"wkid":102100}}}],"sr":{"wkid":102100}}&callback=dojo.io.script.jsonp_dojoIoScript2._jsonpCallbackHere is the web app (but the map server is internal so you wont be able to see that).A six pack to the one who can help me with this!
