Hi
I have some require and function that can not load in arcgisjavascript 4.12:
"dojo/dom",
"dojo/on", "dojo/dom-construct",
"dojo/_base/Color",
"dojo/query",
"dojo/dom", "dojo/on",
"dojo/domReady!",
why?
Anjelina,
OK, I see what you are thinking. Just because the module does not look like it is loaded it actually is and here is code that proves it. I took your exact require and added it to a esri sample and when you click on the view you will see that dom, on, and domConstruct are all operating normally:
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1,maximum-scale=1,user-scalable=no"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Intro to MapImageLayer <SPAN class="operator token">-</SPAN> <SPAN class="number token">4.12</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.12/esri/themes/light/main.css"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.12/"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #viewDiv <SPAN class="punctuation token">{</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/identity/OAuthInfo"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/identity/IdentityManager"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/WebScene"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/Locator"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/ScaleBar"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Slider"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Search/SearchSource"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/renderers/SimpleRenderer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/FillSymbol3DLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/config"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/SceneView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Camera"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/WMSLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/TileLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/BingMapsLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/ElevationLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/BaseElevationLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Search"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Polyline"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Polygon"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/Geoprocessor"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/support/LinearUnit"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/support/FeatureSet"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/request"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/SceneLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Home"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/DirectLineMeasurement3D"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/AreaMeasurement3D"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/query"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/MeshSymbol3D"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/MapImageLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/LayerList"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/geometryEngine"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Legend"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/Font"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/PolygonSymbol3D"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/TextSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/OpenStreetMapLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Sketch/SketchViewModel"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/Layer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Expand"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Viewpoint"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/core/watchUtils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/core/urlUtils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/support/DataFile"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-construct"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/PictureMarkerSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/renderers/support/jsonUtils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/renderers/UniqueValueRenderer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/_base/Color"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/support/Query"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/QueryTask"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/PathSymbol3DLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/LineSymbol3D"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/LineSymbol3DLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/CoordinateConversion"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/CoordinateConversion/support/Format"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/CoordinateConversion/support/Conversion"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/support/webMercatorUtils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Sketch/SketchViewModel"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Track"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> OAuthInfo<SPAN class="punctuation token">,</SPAN> esriId<SPAN class="punctuation token">,</SPAN> WebScene<SPAN class="punctuation token">,</SPAN> Map<SPAN class="punctuation token">,</SPAN> Locator<SPAN class="punctuation token">,</SPAN> ScaleBar<SPAN class="punctuation token">,</SPAN> Slider<SPAN class="punctuation token">,</SPAN> SearchSource<SPAN class="punctuation token">,</SPAN> SimpleRenderer<SPAN class="punctuation token">,</SPAN> FillSymbol3DLayer<SPAN class="punctuation token">,</SPAN> esriConfig<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> SceneView<SPAN class="punctuation token">,</SPAN> Camera<SPAN class="punctuation token">,</SPAN> WMSLayer<SPAN class="punctuation token">,</SPAN> TileLayer<SPAN class="punctuation token">,</SPAN> BingMapsLayer<SPAN class="punctuation token">,</SPAN> ElevationLayer<SPAN class="punctuation token">,</SPAN> BaseElevationLayer<SPAN class="punctuation token">,</SPAN> Search<SPAN class="punctuation token">,</SPAN> Point<SPAN class="punctuation token">,</SPAN> Polyline<SPAN class="punctuation token">,</SPAN> Polygon<SPAN class="punctuation token">,</SPAN> Geoprocessor<SPAN class="punctuation token">,</SPAN> LinearUnit<SPAN class="punctuation token">,</SPAN> FeatureSet<SPAN class="punctuation token">,</SPAN> esriRequest<SPAN class="punctuation token">,</SPAN> SceneLayer<SPAN class="punctuation token">,</SPAN> Home<SPAN class="punctuation token">,</SPAN> DirectLineMeasurement3D<SPAN class="punctuation token">,</SPAN> AreaMeasurement3D<SPAN class="punctuation token">,</SPAN> query<SPAN class="punctuation token">,</SPAN> GraphicsLayer<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> MeshSymbol3D<SPAN class="punctuation token">,</SPAN> MapImageLayer<SPAN class="punctuation token">,</SPAN> LayerList<SPAN class="punctuation token">,</SPAN> geometryEngine<SPAN class="punctuation token">,</SPAN> Legend<SPAN class="punctuation token">,</SPAN> Font<SPAN class="punctuation token">,</SPAN> SimpleLineSymbol<SPAN class="punctuation token">,</SPAN> PolygonSymbol3D<SPAN class="punctuation token">,</SPAN>TextSymbol<SPAN class="punctuation token">,</SPAN> OpenStreetMapLayer <SPAN class="punctuation token">,</SPAN>SketchViewModel<SPAN class="punctuation token">,</SPAN> Layer<SPAN class="punctuation token">,</SPAN> Expand<SPAN class="punctuation token">,</SPAN> Extent<SPAN class="punctuation token">,</SPAN> Viewpoint<SPAN class="punctuation token">,</SPAN> watchUtils<SPAN class="punctuation token">,</SPAN> urlUtils<SPAN class="punctuation token">,</SPAN> DataFile<SPAN class="punctuation token">,</SPAN> dom<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">,</SPAN> domConstruct<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">,</SPAN>PictureMarkerSymbol<SPAN class="punctuation token">,</SPAN> rendererJsonUtils<SPAN class="punctuation token">,</SPAN> UniqueValueRenderer<SPAN class="punctuation token">,</SPAN> Color<SPAN class="punctuation token">,</SPAN> Query<SPAN class="punctuation token">,</SPAN> QueryTask<SPAN class="punctuation token">,</SPAN> PathSymbol3DLayer<SPAN class="punctuation token">,</SPAN> LineSymbol3D<SPAN class="punctuation token">,</SPAN> LineSymbol3DLayer<SPAN class="punctuation token">,</SPAN> CoordinateConversion<SPAN class="punctuation token">,</SPAN> Format<SPAN class="punctuation token">,</SPAN> Conversion<SPAN class="punctuation token">,</SPAN> webMercatorUtils<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">,</SPAN> SketchViewModel<SPAN class="punctuation token">,</SPAN> Track <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">/***************************************************************** * Create a MapImageLayer instance pointing to a Map Service * containing data about pool permits in Southern California. *****************************************************************/</SPAN> <SPAN class="keyword token">var</SPAN> permitsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapImageLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new PortalItem()</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"d7892b3c13b44391992ecd42bfa92d01"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/***************************************************************** * Add the layer to a map *****************************************************************/</SPAN> <SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"dark-gray"</SPAN><SPAN class="punctuation token">,</SPAN> layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>permitsLayer<SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SceneView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> map <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/***************************************************************** * Animate to the layer's full extent when the layer loads. *****************************************************************/</SPAN> permitsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">goTo</SPAN><SPAN class="punctuation token">(</SPAN>permitsLayer<SPAN class="punctuation token">.</SPAN>fullExtent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>view<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'click'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"view was clicked"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> newDiv <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toDom</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"<div>I'm a Node</div>"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">place</SPAN><SPAN class="punctuation token">(</SPAN>newDiv<SPAN class="punctuation token">,</SPAN> dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
That was my mistake in writing the above question.
require([ "esri/identity/OAuthInfo", "esri/identity/IdentityManager", "esri/WebScene", "esri/Map", "esri/tasks/Locator", "esri/widgets/ScaleBar", "esri/widgets/Slider","esri/widgets/Search/SearchSource", "esri/renderers/SimpleRenderer", "esri/symbols/FillSymbol3DLayer", "esri/config", "esri/views/MapView", "esri/views/SceneView", "esri/Camera", "esri/layers/WMSLayer", "esri/layers/TileLayer", "esri/layers/BingMapsLayer", "esri/layers/ElevationLayer", "esri/layers/BaseElevationLayer", "esri/widgets/Search", "esri/geometry/Point", "esri/geometry/Polyline", "esri/geometry/Polygon", "esri/tasks/Geoprocessor", "esri/tasks/support/LinearUnit", "esri/tasks/support/FeatureSet", "esri/request", "esri/layers/SceneLayer", "esri/widgets/Home", "esri/widgets/DirectLineMeasurement3D", "esri/widgets/AreaMeasurement3D", "dojo/query", "esri/layers/GraphicsLayer", "esri/Graphic","esri/symbols/MeshSymbol3D", "esri/layers/MapImageLayer","esri/widgets/LayerList", "esri/geometry/geometryEngine", "esri/widgets/Legend", "esri/symbols/Font", "esri/symbols/SimpleLineSymbol", "esri/symbols/PolygonSymbol3D", "esri/symbols/TextSymbol", "esri/layers/OpenStreetMapLayer", "esri/widgets/Sketch/SketchViewModel", "esri/layers/Layer", "esri/widgets/Expand", "esri/geometry/Extent", "esri/Viewpoint", "esri/core/watchUtils",
"esri/core/urlUtils", "esri/tasks/support/DataFile", "dojo/dom", "dojo/on", "dojo/dom-construct", "esri/layers/FeatureLayer", "esri/symbols/PictureMarkerSymbol", "esri/renderers/support/jsonUtils", "esri/renderers/UniqueValueRenderer", "dojo/_base/Color", "esri/tasks/support/Query", "esri/tasks/QueryTask", "esri/symbols/PathSymbol3DLayer", "esri/symbols/LineSymbol3D", "esri/symbols/LineSymbol3DLayer", "esri/widgets/CoordinateConversion", "esri/widgets/CoordinateConversion/support/Format", "esri/widgets/CoordinateConversion/support/Conversion", "esri/geometry/support/webMercatorUtils", "esri/geometry/SpatialReference", "esri/widgets/Sketch/SketchViewModel", "esri/widgets/Track", "dojo/domReady!", ], function(
OAuthInfo, esriId, WebScene, Map, Locator, ScaleBar, Slider, SearchSource, SimpleRenderer, FillSymbol3DLayer, esriConfig, MapView, SceneView, Camera, WMSLayer, TileLayer, BingMapsLayer, ElevationLayer, BaseElevationLayer, Search, Point, Polyline, Polygon, Geoprocessor, LinearUnit, FeatureSet, esriRequest, SceneLayer, Home, DirectLineMeasurement3D, AreaMeasurement3D, query, GraphicsLayer, Graphic, MeshSymbol3D, MapImageLayer, LayerList, geometryEngine, Legend, Font, SimpleLineSymbol, PolygonSymbol3D,TextSymbol, OpenStreetMapLayer ,SketchViewModel, Layer, Expand, Extent, Viewpoint, watchUtils, urlUtils, DataFile, dom, on, domConstruct, FeatureLayer,PictureMarkerSymbol, rendererJsonUtils, UniqueValueRenderer, Color,Query, QueryTask, PathSymbol3DLayer, LineSymbol3D, LineSymbol3DLayer, CoordinateConversion, Format, Conversion, webMercatorUtils, SpatialReference, SketchViewModel,Track )
Can you post more of your code? It is strange that you have several modules listed twice.
