use FeatureLayer to assign to FeatureDataGrid.GraphicsLayer property if you want to preserve field information, instead of performing a QueryTask and then putting results to a GraphicsLayer. You can still perform queries using FeatureLayer by updating Where clause.
<esri:FeatureLayer ID="MAINPOINTS" DisableClientCaching="True" AutoSave="False" Url="http://myserver/ArcGIS/rest/services/gdb/FeatureServer/0" OutFields="*" Mode="OnDemand">
<Grid> <Grid.RowDefinitions> <RowDefinition Height="15" /> <RowDefinition Height="*" /> </Grid.RowDefinitions> <TextBlock x:Name="DataDisplayTitle" Text="Search Results" FontSize="9" Grid.Row="0" FontWeight="Bold" FontFamily="Arial" Foreground="#FFFFFFFF" /> <esriWidgets:FeatureDataGrid Grid.Row="1" x:Name="QueryDetailsDataGrid" Height="170" Map="{Binding ElementName=Map}" GraphicsLayer="{Binding Layers[MySelectionGraphicsLayer], ElementName=Map}" Style="{StaticResource FeatureDataGridStyle1}" /> </Grid>
string baseUrl = "http://myserver/ArcGIS/rest/services/gdb/MapServer"; for (int i = 0; i <= 1; i++) { FeatureLayer featureLayer = new FeatureLayer() { Url = string.Format("{0}/{1}", baseUrl, i) }; featureLayer.Initialize(); layers.Add(featureLayer); } //layers.RemoveAt(1); Layers.ItemsSource = layers; Layers.SelectedIndex = 0;
#region Spatial Query private void esriTools_ToolbarItemClicked(object sender, ESRI.ArcGIS.Client.Toolkit.SelectedToolbarItemArgs e) { switch (e.Index) { case 0: // Point MyDrawSurface.DrawMode = DrawMode.Point; break; case 1: // Polyline MyDrawSurface.DrawMode = DrawMode.Polyline; break; case 2: // Polygon MyDrawSurface.DrawMode = DrawMode.Polygon; break; case 3: // Rectangle MyDrawSurface.DrawMode = DrawMode.Rectangle; break; default: // Clear MyDrawSurface.DrawMode = DrawMode.None; GraphicsLayer selectionGraphicslayer = Map.Layers["MySelectionGraphicsLayer"] as GraphicsLayer; selectionGraphicslayer.ClearGraphics(); QueryDetailsDataGrid.ItemsSource = null; ResultsDisplay.IsExpanded = false; break; } MyDrawSurface.IsEnabled = (MyDrawSurface.DrawMode != DrawMode.None); StatusTextBlock.Text = e.Item.Text; } private void MyDrawSurface_DrawComplete(object sender, ESRI.ArcGIS.Client.DrawEventArgs args) { GraphicsLayer selectionGraphicslayer = Map.Layers["MySelectionGraphicsLayer"] as GraphicsLayer; selectionGraphicslayer.ClearGraphics(); QueryTask queryTask = new QueryTask((Layers.SelectedItem as FeatureLayer).Url); queryTask.ExecuteCompleted += QueryTask_ExecuteCompleted; queryTask.Failed += QueryTask_Failed; Query query = new ESRI.ArcGIS.Client.Tasks.Query(); query.OutFields.Add("*"); query.Geometry = args.Geometry; // Return geometry with result features query.ReturnGeometry = true; queryTask.ExecuteAsync(query); } private void QueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args) { FeatureSet featureSet = args.FeatureSet; if (featureSet == null || featureSet.Features.Count < 1) { MessageBox.Show("No features retured from query"); return; } GraphicsLayer graphicsLayer = Map.Layers["MySelectionGraphicsLayer"] as GraphicsLayer; if (featureSet != null && featureSet.Features.Count > 0) // ResultsDisplay.Visibility = Visibility.Visible; { foreach (Graphic feature in featureSet.Features) { switch (featureSet.GeometryType.ToString()) { case "Polygon": feature.Symbol = LayoutRoot.Resources["ResultsFillSymbol"] as FillSymbol; break; case "Polyline": feature.Symbol = LayoutRoot.Resources["CustomGrowLineSymbol"] as LineSymbol; break; case "Point": feature.Symbol = LayoutRoot.Resources["ResultsMarkerSymbol"] as SimpleMarkerSymbol; break; } graphicsLayer.Graphics.Insert(0, feature); } ResultsDisplay.IsExpanded = true; } MyDrawSurface.IsEnabled = false; } private void QueryTask_Failed(object sender, TaskFailedEventArgs args) { MessageBox.Show("Query failed: " + args.Error); } #endregion
