I also have this same situation. Was there any solution for this?
I also tried a Attribute with HTML code for the image and that doesn't seem to work either.?
Any help would be appreciated.
I doubt that raster fields are supported in ArcGIS Online, but maybe Bernie Szukalski can enlighten us on this topic.
In case they are not supported, you could use some Python code to extract the rasters and store them on a server (or even dropbox) and create hyperlinks for each feature. The site below explains shortly how to export the rasters to files.
How to export your raster datasets referenced in a “raster” attribute field (file geodatabase) using Python. | Esri Aus…
Another option would be the use of attachments:
Configure pop-ups—Help | ArcGIS
Kind regards, Xander
Hi.
Finally, The raster field are supported by ArcGIS Online? In ArcGIS Pro for example, this field is not compatible. I tried publish a table with a raster field and attachment, but just the attachment was publish, the raster field don't appear in the database, either the rasters (images) as seen, in ArcGIS Desktop.
Have you any other suggestions or backgroud about this?
Best regards!
Braulio.
