This is a question on using ARCADE within Portal for ArcGIS. I have recently upgraded ArcServer,, Portal, and DataStore to 10.7. This was done primarily to access the tools available such as FeatureSetbyName.
At this point, within Arcade, I am not able to access the profile, especially the popup which has the $map. I can add the function to the script editor window, but upon test, all I get is ":Runtime Error: Identifier Not Found. $map".
I am not sure why the $map item is not found. Any suggestions?
James
