I use a SQL Server for my Geodatabase.I don't believe a file geodatabase is able to register featureclasses as versioned, you may want to check that.I was also considering to use a File GDB, but opted not to since, I would have to re-code a lot. I am currently using a non registered as versioned dataset, meaning I can't modify the data using ArcMap. This may pose a problem in the future for me. So I am going look into ways of Registering a feature dataset as versioned on the fly, and then unregistering on the fly, using ArcObjects. But this will be in a few months, since I know we want to edits points in ArcMap but be able to synchronize with ArcGIS mobile without issues. I am trying to find a happy balance for my applications.Good luck!
UsageThis tool synchronizes a mobile cache and its associated attachments (if available) with its data source via a map document; this map document is the one that the mobile cache is extracted from. When the tool synchronizes changes between a mobile cache and the map document, this tool checks if the map document has the same schema as the mobile cache by comparing their checksums. The checksum is calculated based on the schema of the selected map layers' data source. If the schema has changed, you will not be able to synchronize changes.By default, the extent to upload or download changes is based on the map document's full extent.Only vector layers based on geodatabase data sources (file-based and enterprise) can be synchronized between the mobile cache and its data source. By default, all layers will be examined, and all edits will be checked in.If the data source is a versioned geodatabase, this tool first uploads edits from the mobile cache to its data source, removes the mobile cache, then re-creates the mobile cache for the specified version.
In the ArcMap doc, does the attribute table have the new points?
