Hello Team,
Is it possible to draw a line with set of points having certain z value over scene?
I tried but line
Thank you,
Girish
Yes, you can use a Tube symbol in Dynamic mode. Here is some code to get you on the right track:
GraphicsOverlay<SPAN class="operator token">*</SPAN> overlay <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">GraphicsOverlay</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> overlay<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">setRenderingMode</SPAN><SPAN class="punctuation token">(</SPAN>GraphicsRenderingMode<SPAN class="operator token">::</SPAN>Dynamic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">auto</SPAN> sceneProps <SPAN class="operator token">=</SPAN> overlay<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">sceneProperties</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> sceneProps<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setSurfacePlacement</SPAN><SPAN class="punctuation token">(</SPAN>SurfacePlacement<SPAN class="operator token">::</SPAN>Absolute<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> overlay<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">setSceneProperties</SPAN><SPAN class="punctuation token">(</SPAN>sceneProps<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> m_sceneView<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">graphicsOverlays</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">append</SPAN><SPAN class="punctuation token">(</SPAN>overlay<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> PolylineBuilder<SPAN class="operator token">*</SPAN> pb <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">PolylineBuilder</SPAN><SPAN class="punctuation token">(</SPAN>SpatialReference<SPAN class="operator token">::</SPAN><SPAN class="token function">wgs84</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> pb<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">addPoint</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> pb<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">addPoint</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">20000</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> pb<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">addPoint</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1.5</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">1.5</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">10000</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> pb<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">addPoint</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1.75</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">1.75</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> SolidStrokeSymbolLayer<SPAN class="operator token">*</SPAN> strokeSymbolLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">SolidStrokeSymbolLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">5000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token function">QColor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"red"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> StrokeSymbolLayerLineStyle3D<SPAN class="operator token">::</SPAN>Tube<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> MultilayerPolylineSymbol<SPAN class="operator token">*</SPAN> tubeSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">MultilayerPolylineSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>strokeSymbolLayer<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> Graphic<SPAN class="operator token">*</SPAN> graphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> graphic<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">setGeometry</SPAN><SPAN class="punctuation token">(</SPAN>pb<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">toGeometry</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> graphic<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">setSymbol</SPAN><SPAN class="punctuation token">(</SPAN>tubeSymbol<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> overlay<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">graphics</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">append</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
