public static Task<string> GetToken(string userName, string password) { var tcs = new TaskCompletionSource<string>(); string jsonData = "f=json&username=" + userName + "&password=" + password + "&referer=" + "http://arcgis.com" + "&request=getToken"; WebClient getTokenClient = new WebClient(); getTokenClient.Headers["Content-Type"] = "application/x-www-form-urlencoded"; getTokenClient.UploadStringCompleted += (sender, e) => { JObject obj = JObject.Parse(e.Result.ToString()); tcs.TrySetResult(obj["token"].ToString()); }; getTokenClient.UploadStringAsync(new Uri("https://www.arcgis.com/sharing/rest/generateToken"), "Post", jsonData); return tcs.Task; }
Without the code the only thing that we can do is to guess what you might possibly be doing wrong.Post the code.
private void login_Click(object sender, RoutedEventArgs e) { string url = "https://www.arcgis.com/sharing/generateToken"; IdentityManager.Current.TokenGenerationReferer = <My IP Address which i got form http://Whatsmyip.com>; IdentityManager.Current.GenerateCredentialAsync(url, UserName.Text, Password.Password, (credential, ex) => { if (ex == null) { AddFeatureLayers(credential.Token); } }); } public void AddFeatureLayers(credential.Token){ MyFeatureLayer = new FeatureLayer { ID = "TrucksLayer", Url = "<AGOL Feature Layer URL>", Token = Token }; MyFeatureLayer .OutFields.Add("*"); MyFeatureLayer .Initialized += new EventHandler<EventArgs>(MyFeatureLayer_Initialized); MyFeatureLayer .InitializationFailed += new EventHandler<EventArgs>(MyFeatureLayer_InitializationFailed); _map.Layers.Add(MyFeatureLayer ); } void MyFeatureLayer_Initialized(object sender, EventArgs e) { Console.WriteLine("Layer initialized"); } void MyFeatureLayer_InitializationFailed(object sender, EventArgs e) { Console.WriteLine("Layer not initialized"); }
It might be because you generate tokens that are not associated to a referer.Try by setting IdentityManager.Current.TokenGenerationReferer = <substring of your SL app URL> (e.g "http".
