Dear All,
My Project manager want a custom report like the image given below.how can i achieve this task using arcgis java script api.please help.Thanks in advance
Hi, we most often see customers approaching functionality such as this through a print service. We have a print widget that makes it simple to implement in the JavaScript API. It is possible to create custom print templates with your own print service if desired.
Dear Andrew ,
I am using arcgis java script 3.29.how to achieve this task in that api.
Thanks in advance.
Hi Nadir,
For javascript side you can refer to that : Print | ArcGIS API for JavaScript 3.29
In order to use your desire print layout like what you described, it is better to publish print gp task with custom layout.
And then use that gp task by above js reference link I mentioned.
Below is how to publish
Publish an additional print service with custom layouts from ArcMap—Documentation (10.7) | ArcGIS Enterprise
Share a print service web tool with custom layouts from ArcGIS Pro—Documentation (10.7) | ArcGIS Enterprise
