Could someone help why I'm having Error 210 on this script?
For info, I'm running the script using ArcGIS Notebook with ArcGIS Pro.
a *.dbf file has to go into a folder, If you want a geodatabase table, then a *.gdb needs to be specified
Your workspace name doesn't look right
Actually, my workspace is a folder. I named it specifically like that. And i tried to rename it as well but it's still not working.
Try a folder that is different, or "raw encode the folder path. Either the \U will make the path unusable, or the \n later on
p <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:\Users\jrm236admin\Documents\new\Hurricane\folder\hurricane_dbf.dbf"</SPAN> File <SPAN class="string token">"<ipython-input-1-e0812d7d099a>"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">1</SPAN> p <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:\Users\jrm236admin\Documents\new\Hurricane\folder\hurricane_dbf.dbf"</SPAN> <SPAN class="operator token">^</SPAN> SyntaxError<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">(</SPAN>unicode error<SPAN class="punctuation token">)</SPAN> <SPAN class="string token">'unicodeescape'</SPAN> codec can't decode bytes <SPAN class="keyword token">in</SPAN> position <SPAN class="number token">2</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">:</SPAN> truncated \UXXXXXXXX escape <SPAN class="comment token"># ---- raw encoded... a little 'r' goes a long way</SPAN> p <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"C:\Users\jrm236admin\Documents\new\Hurricane\folder\hurricane_dbf.dbf"</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>p<SPAN class="punctuation token">)</SPAN> C<SPAN class="punctuation token">:</SPAN>\Users\jrm236admin\Documents\new\Hurricane\folder\hurricane_dbf<SPAN class="punctuation token">.</SPAN>dbf<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks, Dan! But is there a way to raw encode the output with TableToTable function. It's asking for both the output path and output name. And there's no option to raw encode the output.
