import arcpy import os # Script arguments and variables sNetwork = arcpy.GetParameterAsText(0) Flags = arcpy.GetParameterAsText(1) Barriers = arcpy.GetParameterAsText(2) Trace_Results = Flags LayerList = ["gas_main", "service_line", "service_point"] EdgeList = [True, True, False] iOutParameter = 3 try: arcpy.env.workspace = "in_memory" sScratchWS = arcpy.env.scratchFolder # Perform trace arcpy.AddMessage("Tracing...") arcpy.TraceGeometricNetwork_management( sNetwork, Trace_Results, Flags, "FIND_CONNECTED", Barriers) # Extract feature sets from group layer for i in range(len(LayerList)): sLayer = LayerList bEdge = EdgeList arcpy.AddMessage("Processing results (" + sLayer + ")...") SelectResults = arcpy.SelectData_management(Trace_Results, sLayer) SelectLayer = SelectResults.getOutput(0) TempName = arcpy.CreateUniqueName(sLayer) if bEdge: # Densify_edit (to remove curves) is not supported in Runtime # Workaround: export features to shapefile TempShpName = arcpy.CreateUniqueName(sLayer + ".shp", sScratchWS) arcpy.AddMessage("TempShpName = " + TempShpName) arcpy.CopyFeatures_management(SelectLayer, TempShpName) arcpy.CopyFeatures_management(TempShpName, TempName) arcpy.Delete_management(TempShpName) else: arcpy.Select_analysis(SelectLayer, TempName, None) OutFeatureSet = arcpy.FeatureSet() OutFeatureSet.load(TempName) arcpy.SetParameter(iOutParameter, OutFeatureSet) iOutParameter += 1 except Exception, ErrorDesc: sErr = "ERROR:\n" + str(ErrorDesc) arcpy.AddError(sErr)
