Ismael Chivite
Michele Lundeen
James Crandall
We are interested in using the split screen approach in Quick Capture where we could draw a quick polygon (with a fingertip or stylus using the imagery basemap) instead of streaming one. We need to draw quick polygons that are offset from our current location. Is/will that functionality be available in the future?
Idea raised here: https://community.esri.com/t5/arcgis-quickcapture-ideas/add-polygon-draw-tool-to-quick-capture-to-create-polygons-offset/idi-p/1040564/jump-to/first-unread-message
Hi Ismael,
Any update to the above idea? We are now in the final stages of researching/selecting the app(s) that would meet the requirements listed above in James Crandall's post. I have read about the Field Maps app but I still believe we were closer to accomplishing our complete project goals with the split screen tablet view in Quick Capture. The only functionality missing is the ability to draw a polygon offset from the location of the device. ismael chivite
Thank you.
Ideally, we would like to have the same polygon draw tool from Survey123 as a way to take our polygon in Quick Capture.
Thanks James. This is useful.
Give us some time to think about this.
Hi Johnathan,
Just to add to the conversation a bit, but I'll defer to Amy as she has a very good understanding of the full requirements.
Please share a bit more about your workflow and why you think QuickCapture is the most suitable choice.
Basic Requirements:
1. Map viewer & attribute entry on same screen layout. No hoping between pages or tabs.
2. Hotkeys as the attribute entry method.
3. Ability to draw points, lines or polygons.
4. onComplete of any draw feature action, click a hotkey to assign the attribute value to that feature.
5. Operate in a disconnected state and upon established connection, update each/all feature services.
Have you considered using other apps more suited to this workflow, such as Collector or Survey123?
Yes! However, both of these apps do not meet requirement #1 or #2 listed above.
As you can tell, we seem to fall right between existing solutions of QuickCapture & Survey123/Collector.
Thanks for any response and info you provide!
Take care,
James
Hi Amy,
This is not currently in our product plan as the idea of QuickCapture is to allow quick data capture at the push of a button. Have you considered using other apps more suited to this workflow, such as Collector or Survey123? Both of these apps allow the digitization of lines and polygons.
John
