The watermark should go away if it is licensed correctly. Do you see this in your main.cpp?
<SPAN class="property macro token">#ifdef kLicense</SPAN> QCoreApplication<SPAN class="operator token">::</SPAN><SPAN class="token function">instance</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">setProperty</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Esri.ArcGISRuntime.license"</SPAN><SPAN class="punctuation token">,</SPAN> kLicense<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="property macro token">#endif</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
