Actually I am seeing this now. So I have to publish my MXD with feature access and then write the code as type="feature" and myserver/***/featureservice/(layer#)I am seeing a strange error though when I try and upload to my server:Service was published but cannot be started due to: Configuration Campus_assets_cartlab.MapServer can not be started.Server Object instance creation failed on machine gis.any thoughts?
Layer: xyz does not use SDE GeoDatabase. Feature Access capabilty requires the data to be on SDE GeoDatabase.
Oh yes, but without using a widget and to be able to just click on the features to pull the attributes, then they must be ArcSDE?
@jrfishe1 So the only way to get the attribute data from the layers is to use ArcSDE?
Yes, "feature services" are different from WFS, and are only supported with Server 10. Just set the type to "dynamic" and you can use your http://yourserver.com/yourinstance/rest/services/yourservice/MapServer/ link. I thought you needed the specific feature service functionality, but if not just use dynamic and you'll be fine.
I created a new map service with WFS enabled, but I am still only seeing one service (a map service) listed on my REST page. I'm currently using ArcGIS Server 9.3. Is this something that's only available with ArcGIS Server 10?
Just go to your REST home page (e.g. http://yourserver.com/yourinstance/rest/services/), and you will see that each map service with Feature capability enabled has two entries, one Map Server entry and another Feature Server entry (and a third if Mobile is enabled). Click on the Feature Server link, then the layer you want. Or you can just manually change the URL, but it's always a good idea to click through via your REST page to make sure the service has been created correctly, is started, etc.
Within a Flex APP. Building a definition Expression and tying it together is no big deal. I would like to do this in the Flex Viewer. How do I send this to a featurelayer within the Config.xml?
Thanks! I was indeed specifying the particular layer, but I didn't realize there was a different service type for individual features within a map service. I'm unfamiliar with feature services (I'm assuming that's what they're called). When I click on the layer I want, the URL still indicates "MapServer", as opposed to "FeatureServer". Is there a particular process I need to go through to create feature services?
To add a feature layer, you need to specify a particular layer, rather than the whole service. For example:http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/FeatureServer/2as opposed to a dynamic map service which would work with:http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/MapServerNote that the feature service specifies a layer with a number at the end of the URL. From the service's FeatureServer page in REST, click the layer you want to get the new URL to use.
