All,
I'm having an issue connecting a script i developed in IDLE with a Tool in ArcCatalog. Here is the import statement from the script:
from xlrd import open_workbook
import xlwt
from xlutils.copy import copy
import arcpy
import subprocess
...and so on. The script works fine in IDLE, but the error I get while trying to run the tool in ArcCatalog is "ImportError: No module named xlrd"
I imagine this has something to do with where this library is located on my machine, e.g. it isnt found in the places Arc would want it to be. Here is where I have xlrd, xlwt, and xlutils folders saved on my machine: (I'm running 10.1 btw)
C:\Python27\ArcGISx6410.1\Lib
This obviously differs from where arcpy is saved, but it is the same general location of plenty of the other native python libraries are.
Any thoughts on where I should put these libraries so that Arc will "see" them?
Thanks!
